Sandblasting - JeepForum.com
post #1 of 3 Old 06-11-2001, 09:46 PM Thread Starter
73seejayfive
Post Sandblasting
I'm getting ready to remove the tub of my Cj5 and sandblast the tub and frame. Should the welding of rusted footwells be done before sandblasting? Does anyone have any suggestions on the type of sand, weight, pressure, etc. to use?
Also, I'm thinking about applying POR-15 to the frame and underside of tub when I finish. Any suggestions regarding this application?
73seejayfive is offline
post #2 of 3 Old 06-13-2001, 06:43 PM
commando
Post
Ever tried Sandpaper?
Just kidding. I saw you weren't getting any replies so I thought I'd drop you a line!
commando is offline
post #3 of 3 Old 06-23-2001, 11:50 PM
gosling1
gosling1's Avatar
Post
Any time an agressive means of cleaning something, some metal is removed. I have used crushed walnut shells and just enough pressure to remove the paint or rust I was working on. Take your time and watch what the blasting is doing. It is easier to step up gradually than it is to replace metal.
2.5" Lift, no track bar, no sway bars, dual K&N filters, custom exhaust stack, custom front and rear bumpers, welded front and rear
Tango Uniform
gosling1 is offline
sandblasting a tub ohio77cj7 Jeep CJ Forum 9 07-24-2009 03:50 PM
Wet sandblasting craigb86 Jeep CJ Forum 28 02-21-2009 05:59 PM
Sandblasting steveracer67 Jeep CJ Forum 10 04-11-2008 08:30 PM
Sandblasting collinpyle Jeep CJ Forum 27 06-17-2007 05:26 AM
Sandblasting jeepwillies Jeep CJ Forum 4 08-28-2003 01:49 PM
