saga continues - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > saga continues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineXJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 06-12-2010, 05:19 PM   #1
cj7texas
saga continues
Searched the forum...followed several links...still not luck locating a Liquid Check Valve for my 84' CJ7. I have converted to the Mopar EFI system and wonder if I need this setup any more. How is the fuel system vented on a YJ? Can I convert to that system since I am essentially using a YJ EFI system?
cj7texas is offline   Reply With Quote
Unread 06-12-2010, 05:34 PM   #2
cj7texas
Liquid Check Valve saga continues
Searched the forum...followed several links...still not luck locating a Liquid Check Valve for my 84' CJ7. I have converted to the Mopar EFI system and wonder if I need this setup any more. How is the fuel system vented on a YJ? Can I convert to that system since I am essentially using a YJ EFI system?[/QUOTE]
Unread 06-13-2010, 08:06 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You have the 15 gallon tank I take it right? I know up to a 91 YJ parts can fit I think.
Did you try this link: Replacements for Liquid Check Valve/Roll Over valve
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
