safetly mounting d-rings on custom front bumper
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
i have 5/8 d-ring and the are hung on solid 1x2 stock through a 1/4" fab bumper.
how many bolts would be enough for general use on the trails and still avoiding ripping you frame apart? pics would be cool but any input welcome
#2 |
Depends on the D-rings but 2 can work I would go for 4 grade 8 bolts with a backing plate installed if you can install it behind the D-rings. If you cant get in there you can drill through install some sleeves so you don't crush anything from the rear of the bumper and install a backing plate there. Make sure the front is just big enough to put the bolt through. Just be sure you paint all the bare metal with a good paint. If you have a welder or access to one weld them on.
#3 |
Senior Member......NOT!!
I did this:
I still have the bumper at work, building a brush guard for it. |
#4 |
^^^ Chet, that is very nice!
Mike My build thread 1979 CJ7, FI 5.0L Ford, NP435, D300, Full floated D44 Detroit, D30 Detroit EZ Locker. |
#5 | |
my d-ring mounts pass through the bumper like that but i made only one hole to mount, i think i will run some angle dowm the out side of the frame to sister it up. keep in mind i'm using only grinders, torch, drills, and welding machine no machine tools |
#6 |
Wow! Nice heavy duty fab Chet!
#7 |
Thanks for the positive responses. I'm not trying to hijack your thread, I just thought that what I did might provide some inspiration for you. I know that most guys don't have access to the shop I do, but the only three tools I used at work were a milling machine (for the mounts), a bandsaw (for the bumper parts), and of course the Millermatic 250 to put everything together. Eventually when I get it all done I'll post a thread about it, not to blow my own horn, but to provide inspiration for other guys when they fab theri own stuff.
#8 |
Is that steel?
#9 |
The bumper is 6" X 3" X 3/16" Hot-Rolled-Steel. The reciever is 2-1/2" square tube, also HRS. The bumper mounts I made of solid pieces of HRS. I had to machine them with the notches and chamfers so they would fit in the frame rails. I sandblasted everthing so it would be clean when I welded it.
#10 | |
1985 Jeep CJ-7 Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage. USMC 1999-2004 Semper Fi! Torchmate CNC Plasma Table Build / Projects |
#11 |
Chet, very nice.
#12 |
here are my finished products minus heculiner topcoat, wench plate, and bull bar/brush gaurd. the front i may redo down the rod but will serve its purpose for now. i ran into issue mountint the angle iron in front on the drivers side because of the stearing box other then that i think i came out ok
#13 |
Looks good!
#15 |
i have used with consistent good luck the weld-on D rings. then to stop any rattle, squirt in some black silicone and presto, silence. Of course, a weld-on D ring needs something to weld to and a cross member is not it. well done on the integrated bumper and you added the best of all, a front receiver. those are priceless, especially moving around trailers.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
