It's me again... - Page 2 - JeepForum.com
post #16 of 32 Old 12-28-2013, 09:14 AM Thread Starter
goochieman83
2014 JK Wrangler
I hope the same goes here, that's one of the most frustrating things I've dealt with it seems like.
goochieman83 is offline
post #17 of 32 Old 12-28-2013, 04:40 PM
vinnyabs
1983 CJ7
So I thought putting a new one in and still occasionally having the same issue meant something else was wrong. Maybe just go somewhere else for a new starter?
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #18 of 32 Old 12-28-2013, 04:48 PM
jay-h
Originally Posted by vinnyabs View Post
So I thought putting a new one in and still occasionally having the same issue meant something else was wrong....
Normally that's a very valid conclusion. In this case, however, having seen starters not fully engaging on the test bench after just a couple of months, I came to the conclusion that the AZ starters for Jeep 6 have a problem.
It's been nearly a year since I put high end one in, without any more problems.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #19 of 32 Old 01-04-2014, 05:17 PM Thread Starter
goochieman83
2014 JK Wrangler
Well drove the jeep today and after going out and coming back it wouldn't start. Fires up no problem when cold but warmed up starts the same grinding noise again. Crap. About 15-20 starts without issue now back to where I started.
post #20 of 32 Old 01-05-2014, 12:35 AM
billybooster2
1983 CJ8
I know you said it wasnt the ignition... But have you tried starting it by putting jumper cable on starter solenoid? Try that to see if it still gives same issue. If it goes away, its ignition. If not suspect flywheel
billybooster2 is offline
post #21 of 32 Old 01-05-2014, 05:58 AM
jay-h
I think what billybooster2 is suggesting is that there is a problem with the starter relay (not the solenoid) circuit. This could happen the connection drops in and out once the starter has begun to engage. This relay (and associated wiring) is on the firewall just above the starter. Trace the small wired from the solenoid back to find it. There are snap on connectors, make sure they are clean. If you can't find the correct relay, it would be possible to wire in a generic SPST relay to do the job.
I replaced mine but the guy at AZ had a really hard time finding a listing, wound up looking under Dodge truck (though I don't know where he finally found it and don't remember what it was called).
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #22 of 32 Old 01-05-2014, 03:29 PM Thread Starter
goochieman83
2014 JK Wrangler
Copy that. Will attempt to find the relay and might just go ahead and replace the solenoid also. Unfortunately it's 10 degrees out so might have to wait until later this week. Still seems crazy that it would work perfect for a couple weeks then just crap out like that.
post #23 of 32 Old 01-05-2014, 05:28 PM
lucdog
lucdog's Avatar
1980 CJ5
I have not seen the relay you speak of on any of the '76 to '86 CJ's I've had.
The OP has a '77, I do believe YJ's have a relay , but not 100% on that.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #24 of 32 Old 01-05-2014, 06:01 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yeah, the relay thing threw me off too, Bill.
Matt
Matt1981CJ7 is offline
post #25 of 32 Old 01-05-2014, 10:22 PM
vinnyabs
1983 CJ7
Thought I was learning something. No relay on mine. We throwing relays on every circuit now?
vinnyabs is offline
post #26 of 32 Old 01-05-2014, 10:28 PM
billybooster2
1983 CJ8
Originally Posted by lucdog
I have not seen the relay you speak of on any of the '76 to '86 CJ's I've had. The OP has a '77, I do believe YJ's have a relay , but not 100% on that.
I was thinking yhst the key cylinder/ under dash ignition was loose and continuing to engage the starter
No relay there either??? Confused bout that too. I still think shorting the starer solenoid might eliminate or prove my theory
post #27 of 32 Old 01-05-2014, 11:42 PM Thread Starter
goochieman83
2014 JK Wrangler
Ok so starter works great for a couple weeks. Then out of no where starts to grind. The flywheel is fly like a circus trapeze
post #28 of 32 Old 01-05-2014, 11:51 PM Thread Starter
goochieman83
2014 JK Wrangler
Ok so my fiance thought it would be funny to post on my account. I think the flywheel is fine or it would have messed up constantly. Has to be something electrical or starter related. Thinking about buying a green macine and hoping to the jeep gods it works!!!!!!!!!!!!
post #29 of 32 Old 01-05-2014, 11:52 PM Thread Starter
goochieman83
2014 JK Wrangler
Machine.
post #30 of 32 Old 01-06-2014, 09:49 AM
billybooster2
1983 CJ8
Completely unnecessary. Try starting it without key cylinder use. Just try.
