rusty rocker panals and floor pans - JeepForum.com
post #1 of 11 Old 06-20-2002, 08:10 PM Thread Starter
LaredoMan
Post rusty rocker panals and floor pans
i just bought a 84 cj7 laredo about a week ago and i am very exited about restoring it. but i need a little advice on a couple of things. there is rust on the interior side of the rocker panels that has made its way to the outside. i have thought about cutting it out and welding in a new piece. would this be difficult? i can see daylight through the floor pans in a couple of places, should i replace them with the ones in quadratec or just treat them with por 15 and forget about it. any suggestions are greatly appreciated. thanx adam
84 cj7 laredo
LaredoMan is offline
post #2 of 11 Old 06-20-2002, 10:56 PM
only in a jeep cj
Post
It depends on how well you want it fixed. Some would sand blast the sections and use filler and repaint. I would cut the sections out and weld in replacements, but this takes a lot of skill from the metal worker. If you do this method, make sure there is no weight on the area to be removed as this will change things (such as body mount areas)
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 11 Old 06-21-2002, 01:04 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
LaredoMan,
Welcome to the forum & Jeeping . I personally would replace with replacement panels . If you have some experiance It is not a difficult , If you haven't done this before Buy the panels and drive your Jeep to a few bodyshops for prices on install . Your better off taking the parts with you to show what you want done . DON'T Let a shop tell you they can fix what you have on the jeep . Trust me I've worked in the bodyshop business for 18 years . If you want it to last and be right replace as much material as you can .
GOOD LUCK ,
JIM
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #4 of 11 Old 06-21-2002, 01:50 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
Laredoman ,
Saw this on Ebay Check it out floor pan for $100.00 Item #1838296689
JIM
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
JIM79CJ7 is offline
post #5 of 11 Old 06-21-2002, 08:17 AM Thread Starter
LaredoMan
Post
thanks alot guys. any comments on por 15?
84 cj7 laredo
post #6 of 11 Old 06-21-2002, 10:05 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by LaredoMan:
<strong>thanks alot guys. any comments on por 15?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Great stuff! Nuff said!
4wheeler4CJ is offline
post #7 of 11 Old 06-21-2002, 10:27 AM
ArbLockerBoy
Thumbs down
<strong>thanks alot guys. any comments on por 15?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I HATE POR 15.
I Followed their instructions!!! and used the metal ready, The por 15 is peeling off and rusting thru. In some places it's as hard as a rock though. here's what may have happened. Por loves rust right? Well, I sandblasted everything before I painted. POR on bare metal SUCKS!!!!!!!!!!!! it must need rust for the adhesion. Also, When you use the metal ready, it leaves a white film on the metal( Yes, I rinsed it!). I took this white film off by sanding, wire brushing and sandblasting again. maby por needs that white film for some kind of chemical reaction to adhere. Anyway, as you can imagine, I put tons of hours into my frame, axles, fender wells, and other parts and now I have all this por crap that I can't paint over.
By the way, even loose and peeling por is difficult to sandblast off.
ARB Locking, OME Flexing, 6.32 creeping 79 CJ5
http://www.2trackmindoffroadclub.rockcrawler.com/
ArbLockerBoy is offline
post #8 of 11 Old 06-21-2002, 11:46 AM
only in a jeep cj
Post
The problem I have with POR 15 is the hundreds of little bubbles in the finish. Yes I stirred the can instead of shaking it, used the right brush, and followed the directions. I called the company and asked and they didn't know or haven't heard of such. Anyone else?
Ed
1975 CJ-6 1983 CJ-8
post #9 of 11 Old 06-21-2002, 12:14 PM
ArbLockerBoy
Post
As I was applying the por, if I brushed too much I would create some bubbles. I waited a few seconds then did one last stroke to smooth out any inconsistencies
post #10 of 11 Old 06-21-2002, 12:18 PM
jeepinbroder
Post
As far as the floor pan replacement goes, one major deciding factor if you want to do your jeep up right is to check the body mounts on the rest of the tub. If your floor pans and rockers are as rusted as you say they are, there's a good chance your body mounts are rusted out too. If they are in good shape, have at the floor pan replacement. If they are rusted away, you may want to consider a tub swap. YJ tubs fit nicely on the cj frame with a few mods and are a nice way to replace your tub without spending $2500. As far as POR-15, it seems to work great on axles, engines, transfer cases and the like, but when your metal is less porous, like floor pans are, it seems to not set into the material very well. If you attempt this, try to get some 36 grit paper to scratch the metal up quite a bit before marine clean and metal ready.
85 CJ-7
jeepinbroder is offline
post #11 of 11 Old 06-28-2002, 12:30 PM
4wheeler4CJ
Arrow
Nothing will stick to a slick surface unless it is prepped right, anyway, no paint, no bedliner, no fiberglass, etc. It is like painting on glass.
floor pans SavSilvrCJ Jeep CJ Forum 4 08-18-2007 04:50 PM
floor pans leematt Jeep CJ Forum 7 05-06-2007 11:54 AM
Floor Pans Sassy Jeep CJ Forum 4 03-27-2006 02:33 PM
CJ Floor pans? slick2570 Jeep CJ Forum 8 03-22-2006 07:46 PM
Floor pans Tri_X_Troll Jeep CJ Forum 4 01-25-2006 05:28 PM
