Rusty rim reclamation... - JeepForum.com
post #1 of 12 Old 04-09-2010, 01:49 PM Thread Starter
Skerr
I've got these rusty, old, chrome-peeling rims that I wanted to try and reuse. I've got a little sandblasting unit, and it's a beautiful day, so here's what I did!
Pic 1- what I started with
Pic 2- halfway comparison
Pic 3- close up of bad and good
Pic 4- finished, before paint prep
Pic 5- compare between another rim
I was surprised that the chrome didn't come off. The peeling edges smoothed down well. The end finish of the chrome is like a satin and is rough enough to hold a paint. The sand did not cause any issues with rubber or plastic parts, but then I didn't hold in those places very long. The next steps are rust converter, then a primer, then paint. Probably tomorrow...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2 of 12 Old 04-09-2010, 03:32 PM
only in a jeep cj
Yep, right there with you. Got a set of someone else's rust chrome rims so I use a paint stripper spin disk that goes in a drill. Used a few shots of ganvanized spray and finished it off with New Ford Gray. About 15min per wheel.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 12 Old 04-09-2010, 04:10 PM
JoonHoss
2011 JK Wrangler
all I've ever heard (over and over) is that you can't get paint to stick to chrome...
I wish you luck, and look forward to seeing your final results!
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #4 of 12 Old 04-09-2010, 04:29 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Skerr those look really good, nice job. What do you have for a sandblasting unit? I've thought about buying a small cheap one just to have around for odd stuff every now and then.. but I wasn't sure if they really worked any good. Is that what you have?
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #5 of 12 Old 04-09-2010, 06:38 PM Thread Starter
Skerr
Yep... it's little and old! I'll post up a pic tomorrow sometime. It's an old Craftsman. It holds most of a bag of sand. I used to operate it with my oil-less Porter-Cable compressor, but I upgraded to a 60 gal CH. The small compressor would run all of the time, but it still provided enough pressure and volume to work, albeit slowly. A small, cheap sandblasting unit would be a good addition, but I rank sandblasting up there with concrete work and house painting!!
I got a coat of rust converter on late this afternoon. The wheel smoothed out really well. More pics tomorrow.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #6 of 12 Old 04-09-2010, 06:45 PM
mmerlina
mmerlina's Avatar
Ah okay.. maybe I'll look into one. We have a pretty big compressor at the shop that could keep up with stuff like that. I wouldn't use it very often.. but it would be nice to have the option sometimes.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #7 of 12 Old 04-10-2010, 10:59 AM Thread Starter
Skerr
Here are a couple more pics. The rim is after the rust converter has been applied, ~24 hours curing time. It turns rust into iron oxide, which is the black color in the picture. It's important to pay attention to curing times before you paint. Aerosols are usually different from oil-base paints in the time needed before application. Following the rim picture is the simple Craftsman sandblaster that I used. It took about 20 minutes to complete the badly rusted wheel. Before painting I will wipe it down with Acetone to remove dirt, oil, etc. I'll probably use an implement paint as it is very tough and inexpensive. Paint pics later.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #8 of 12 Old 05-09-2010, 09:57 PM Thread Starter
Skerr
Well, I didn't get around to finsihing these rims as quickly as I thought I would. And everybody's seen black rims, but I still wanted to show 'em off! I painted them with Valspar low gloss black implement paint from Tractor Supply... ~$12/QT. It's thick, cheap and durable. They look better in person, but no matter what they're better than rusty chrome! They were still a little tacky when I moved them out into the yard. That was a mistake as every bug in the area flew into them. Not sure I like how the Jeep looks with the current paint. I was thinking of repainting it with the original color... maybe a different color?? What do ya'll think? Ironically, I have a set of 5 NIB black steelies in the shop!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #9 of 12 Old 05-10-2010, 07:41 AM
drkchlde
sandblaster units
I've done a lot of sandblasting restoring vehicles and parts, and I can tell you that if you are going to buy a sandblaster, spend a little more for a pressurized unit. The gravity feed sandblasters don't create enough force to remove paint quickly. The pressurized tanks are just as easy to use (takes slightly longer to put in the sand) but there is a huge difference in pressure. Harbor Freight makes a good tank unit that is often on sale for around $80.
drkchlde is offline
post #10 of 12 Old 05-10-2010, 08:48 AM
nichboy
Hey skerr how much of a lift do you have?
nichboy is offline
post #11 of 12 Old 05-10-2010, 09:04 AM
mavsfan001
1983 CJ7
Good job on thw wheels they came out nice!! Lots better than rusty chrome!!!!! thumbs up!!!!
mavsfan001 is offline
post #12 of 12 Old 05-10-2010, 07:38 PM Thread Starter
Skerr
I never have graduated that far, but it sounds like good advice. I'll be adding that to my shop. Thanks for the tip.
RC 2.5"... doing the same on my son's 5. I bought my kit from JCW. I found a much better deal at Morris 4X4 for my son's rig. In fact, better service, quicker parts arrival, better packaging, more parts in the kit... so shop around.
Thanks. I do appreciate that. Do you think the black rims look okay with the factory color? I'm undecided...
Kerrdog
Go Fish! <*////><
Skerr is offline
83 cj-8 reclamation project. spk454 Jeep CJ Forum 349 08-25-2014 12:30 PM
too rusty andy_mitch92 Jeep CJ Forum 13 06-18-2008 04:00 AM
Rusty Cam is OK, but what about lifters? TheJunkMan2005 Jeep CJ Forum 1 02-13-2006 04:12 PM
Rusty Cam? TheJunkMan2005 Jeep CJ Forum 11 01-19-2006 09:43 AM
Rusty bolts dmrodco Jeep CJ Forum 7 04-23-2003 06:50 AM
