Rusted U-Bolts - JeepForum.com
post #1 of 12 Old 03-29-2005, 07:09 AM Thread Starter
bosrover
Rusted U-Bolts
As i was inspecting for rust on my recently purchased cj i noticed the worst rusted area were the u-bolts at the leaf spring/axle. Actually the nuts and washers are the most rusted. I looked on Quadritec and found a new set of u-bolts with nuts and washers for around $60. Not too bad a price. My question is, what is the best way to get the rusted nut and washers off. Most are so badly rusted that they are pealing in layers. I dont think i could get a socket wrench on them. Should i just cut the u-bolt in half with a cutting wheel? Also, do i have to jack the jeep up if i only do one u-bolt at a time? Thanks.
bosrover is offline
post #2 of 12 Old 03-29-2005, 07:13 AM
schmoken
schmoken's Avatar
Get whatever socket fits tight and beat it on with a hammer then get your breaker bar and get after it. Those old rusty ubolts will snap no problem.
schmoken is offline
post #3 of 12 Old 03-29-2005, 07:44 AM
jadams68
jadams68's Avatar
Don't spend 60 bucks on U-bolts when you're more than likely to buy a lift kit in the near future that will have all of that new hardware included.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #4 of 12 Old 03-29-2005, 07:54 AM Thread Starter
bosrover
it actually does have a lift kit on it. i think it is like a 2" lift kit. not sure what brand. maybe a rancho because that is what the shocks are. everything else looks ok. a little rust on the leaf springs. i am just worried about the u-bolts.
bosrover is offline
post #5 of 12 Old 03-29-2005, 08:34 AM
Mike86CJ7
Just cut 'em off. No amount of PB Blaster and the world's longest "cheater bar" couldn't break the ubolts loose when I put my lift on. A few minutes with a cut off wheel in the angle grinder and they were off.
1986 CJ-7: Fiberglass tub, 5" total lift, 33x12.5 M/T's, 258, Weber, T5, Dana 300, Dana 44 rear
Mike86CJ7 is offline
post #6 of 12 Old 03-29-2005, 08:38 AM
killersheep
Just helped a freind pu a 4 1/2" lift on his jeep. Put it on jack stands and cut the u bolts in the center on top of the shaft with a cutter and they will fall right off. My theory is if you aren't keeping them - cut'em off.
86 CJ7 Laredo- '98 4.0L , '94 Fuel Injection and Electronics, 2 1/2" skyjacker, 3/4" Rock Crusher shackle , 1" body lift, T5, DANA 300, D30 front w/Aussie locker , amc 20 rear w/Aussie locker and Moser axles, 3.31 gears, and 32" BFG MT's.
killersheep is offline
post #7 of 12 Old 03-29-2005, 09:01 AM
jeepskate
"Cut me, Mick..."
Don't waste your time fighting to unbolt stuff that you're just going to toss in the garbage.
jeepskate is offline
post #8 of 12 Old 03-29-2005, 09:12 AM Thread Starter
bosrover
alright so i will cut the u-bolts off with a grinder/cutter. one last question, my drive way is gravel and i have no garage. therefore it will be a bit of a problem putting it on jack stands. i was hoping i could leave on the ground and cut one u-bolt off, install the new one, and then cut the next one off, install, etc. will this be possible or is there too much force on the bolt. if that doesnt work i suppose i will have to get some jack stands and work in the street. just dont want somebody hitting the jeep while i am underneath it.
bosrover is offline
post #9 of 12 Old 03-29-2005, 09:45 AM
Mike86CJ7
Place a piece of 3/4" plywood under the jack stands. Just make sure you give the Jeep a good shake to make sure it's secure before heading under it. I've done this in the past on grass and it works well.
post #10 of 12 Old 04-07-2005, 06:55 AM Thread Starter
bosrover
What size jack stands would i need? Not sure how much the CJ weighs or what weight capacity stands are required. Thanks
bosrover is offline
post #11 of 12 Old 04-07-2005, 07:27 AM
mxg342
mxg342's Avatar
For jeeps (and every other 4wd that I would work on) I would definatley recommend the 6 Ton jack stands. The weight is not the issue. The six tons are high enough to get the jeep in the air.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #12 of 12 Old 04-07-2005, 11:32 AM
BIGJMCCONNELL
1977 CJ7
Agree with MXG. 6 ton jackstands would cover you for sure. You can never have one that is too strong Jackstands For $35 you can't go wrong if you ask me.
As for the U-bolts, see if there is a spring shop around you. Alot of times they can make them for you pretty cheap. I got some made for 22 bucks for all 4.
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
Rusted bolts... impact or by hand? VACJ7 Jeep CJ Forum 13 03-08-2009 08:33 AM
Rusted bolts on windshield hinge farmer-dave Jeep CJ Forum 4 09-13-2006 09:40 AM
Broken and Rusted Bolts Matt in TN Jeep CJ Forum 8 01-08-2006 09:09 PM
will an air compressor get rusted bolts off? humboldt_jeep Jeep CJ Forum 7 04-27-2004 02:40 PM
