Runs perfect then...BAM...I'm stranded
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Have an 86 CJ7 restored top to bottom about 3 yrs ago. The jeep has a 304 with about 4500 miles on it. Use the Jeep for fun and a train station commuter...live in NY. Was driving home one night, doing about 45 mph and the motor just died...pulled over and set up a "come get me". While waiting, it started right up and I proceeded about 1 mile and it died again...pulled over and it started right back up again so I proceeded on my way. Died about 5 or 6 times within 5 miles. I was on the phone with my "come get me" so I could keep her posted on my whereabouts. Finally made it home but have not driven it since. I start it frequently...it runs for a minute then dies...start right back up though, then dies again. All said, I am afraid to take it anywhere since I know its just going to die at some time or another. I'm not the most gifted in electrical or gas flow so I am seeking your opinion on what could be the culprit. Is it electrical or carb related? I checked all electrical coming from the battery and also checked all distributor connections...all is good. What could be the problem? A vacuum problem? Or is it electrical? Please help because I want this thing back on the road.
86' CJ7, 304, T177, Dana 300, dual exhaust, Dana 44's 2" body 3" suspension lift, 12.5x33x15 BFG's |
#2 |
Ignition switch gone/going bad?
C |
#3 |
might be fuel pump
-Blake- |
#4 |
X2 on a possible ignition problem. Have a mech check it out...or atleast an experience buddy.
Problem sucks! Good luck in figuring it out
1985 Jeep CJ-7 Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage. USMC 1999-2004 Semper Fi! Torchmate CNC Plasma Table Build / Projects |
#5 |
Use test light on pos side of coil, start it and see if you have juice there when it stalls. If no juice when it dies go back to ign switch. If yes juice when it dies pull easiest plug wire, use alternate plug and fire up again.(will skip on missing cylinder) does plug continue to spark till last rotation of engine? If it cuts out and then dies after spark failure look at distributor or conections to ECM. If it goes to the bitter end look at fuel.
Good luck. LEO |
#6 |
I'd bet on the ignition module.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc... 2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s............... John N |
#7 |
I've had a similar problem in my 79 CJ5, 304 V8. It was the Electronic Control Unit (ECU). Its a flat square body thingy (approx. 1.5 x 4.5 x 5.5) bolted on the drivers side fender-well right in front of the firewall. When mine warmed up a bit the engine would stop. Let it cool for 10 minutes, the engine would run for another 10 to 20 minutes. I checked spark, grounds, wires, fuseable links, etc. It wasn't until I replaced the ECU that engine stopped playing dead.
Apparently when some electronic devices get weak, they fail when they get hot, then work when they get colder.? It was about $50 5 years ago. |
#8 |
#9 |
What was I thinking
I just replaced my DuraSpark module with an HEI module. No need to replace the distributor.
Replacement DuraSpark module last just long enough to sell the vehical. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
