running in wrong firing order only - JeepForum.com
post #1 of 15 Old 11-06-2010, 04:06 PM Thread Starter
jason11673
1981 CJ7
my 258 only runs in wrong firing order. i set it to the correct order and will not start. in the firing order that i bought it in carb pops unless the #2 plug wire is un plugged. any help would be great
jason11673 is offline
post #2 of 15 Old 11-06-2010, 07:31 PM
gojeepin
1983 CJ7
I feel like a walked into the middle of a conversation. There is too much information missing, like...
Did it start doing this out of the blue?
Did you install a new distributor?
Did you turn the existing distributor?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 15 Old 11-06-2010, 08:11 PM
mknight759
?????? I believe as long as there in the correct order around the cap they will work no matter were #1 is but i could be wrong < usually are >
mknight759 is offline
post #4 of 15 Old 11-06-2010, 08:58 PM
tucsonaz86cj7
Chiltons manual best investment of your life.
tucsonaz86cj7 is offline
post #5 of 15 Old 11-07-2010, 07:53 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well, almost. as long as the rotor is pointing at the right terminal at the right time.
Did you check the compression? Maybe the intake valve is stuck open. That will mess with things.
John Strenk is offline
post #6 of 15 Old 11-07-2010, 11:38 AM
tucsonaz86cj7
Going to upload the firing order for you Jeep in a minute
post #7 of 15 Old 11-07-2010, 11:49 AM
tucsonaz86cj7
post #8 of 15 Old 11-07-2010, 12:42 PM
mknight759
I tell you what I did I took my distributor apart to change it from the 13 deg to the 18 deg advance and well the dist gear didnt go back on the right way. Yea well it had a miss to it took a little while to figure it out.
post #9 of 15 Old 11-12-2010, 06:08 PM
philjeep
if you have had your distributor apart and have put the drive pick up cog on the bottom of it on the other way it will spin in the other way . remove your cap and make sure its spinning the correct direction when winding the motor over. if it isnt just put your leads on in the right order starting at number 1 but going round the cap backwards..
philjeep is offline
post #10 of 15 Old 11-12-2010, 06:54 PM
Trapshooter
A backfire through the carb is only caused by two things. Excessively lean air/fuel mixture or incorrect timing.
Somehow the #2 cylinder is out of time.
Good Luck........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #11 of 15 Old 11-13-2010, 05:19 AM
John Strenk
1976 CJ5
are you spark plug wires running close to each other? sometimes you can get a cross fire that way.
post #12 of 15 Old 11-13-2010, 07:03 AM
Lordwrench
1978 CJ7
you need to compression test #2,your valve is staying open and sending the combustion charge out the intake. If it runs smooth except for the popping,it is bad valve or valve train component on #2 cylinder,intake side.Let us know the answer,hope it is simple fix.
Lordwrench is offline
post #13 of 15 Old 11-13-2010, 07:11 PM
John Strenk
1976 CJ5
That's what I was thinking. I mentioned it about 6 days ago and still waiting for a reply.
post #14 of 15 Old 05-08-2013, 09:11 AM
nekamc
Push rods not in correct spot
nekamc is offline
post #15 of 15 Old 05-08-2013, 01:05 PM
John Strenk
1976 CJ5
Yeah, I was wondering if he ever got it running, 3 years ago....
Do I need to be a vendor in order to inform forum about group buys? Kyle95sr5 JeepForum Announcements 1 03-05-2010 02:18 PM
time is wrong wildman90 JeepForum Announcements 7 12-09-2008 05:44 AM
When you post it is in RANDOM order??! Deezul JeepForum Announcements 2 07-29-2006 09:39 AM
replys changing order SGT.CAP JeepForum Announcements 5 07-18-2006 02:43 PM
Something wrong with vbulletin? Luksi JeepForum Announcements 3 06-10-2006 12:54 PM
