Running hotter on highway - Page 2 - JeepForum.com
post #16 of 20 Old 09-18-2011, 06:17 PM
lucdog
1980 CJ5
Originally Posted by foggybottombob
I'm not buying this at all.
When you are driving at speed, the fan can be not turning at all, turning slow, turning 2 times slow or turning really fast and the air flow change through the radiator will be negligible. I have an electric 2 speed fan that I can turn on hi, low or off and it makes no difference in coolant temp when you are driving fast. The no clutch fan will add a little more drag on your engine at high rpm but I would guess that factor is less than 5 horsepower.
Now if you are getting detonation (pinging) your engine will definitely heat up really fast at high speed. You might try some higher octane gas for a tank.
I agree with Foggy on this. Back in the day (60's) IIRC most cars had fixed fans. I don't ever remember my father complaining or having to slow down because of overheating.
I dought if every CJ with a fixed fan, went back to the dealership, for overheating at hiway speeds.
In fact my DD 1983,258,2.72 gears, 31" tires, fixed 4 blade fan, and 2 core old radiator, will run all day at 70 mph without the temp rising
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #17 of 20 Old 09-18-2011, 06:21 PM
jumbojeepman
1976 CJ7
I'm not buying this either. Slow fan speed is causing air to back up, so making the fan turn even slower will help out?
The reason for my doubt: I have a Mercedes 300E. It has 2 pusher electric fans in front of the radiator, and 1 mechanical fan behind the radiator. I was having a problem overheating at stop and low speeds. Once you got over 45 the engine cooled just fine. The eventual problem I discovered: One of the electric fans was spinning backwards! That's right, it was pushing air away from the radiator. In spite of this, once you got moving over 45 the air rushing through the grille was enough to overcome this and cool the engine sufficiently, even in the summer with the AC on.
My guess as to the actual problem is a bad radiator.
jumbojeepman is offline
post #18 of 20 Old 09-18-2011, 07:33 PM
Foundrydude
You don't have to buy it, but I didn't make it up. It's a known phenomenon with fixed mechanical fans. When you have a 60s style blade with only four tiny airfoils the effect is less but if you have a more agressive truck fan it's very real.
good luck to the OP
Foundrydude is offline
post #19 of 20 Old 09-18-2011, 08:04 PM
brownbagg
1930 MK Compass
but the air is going through the radiator before it hits the fan. the fan is no different from the front of the engine itself.
brownbagg is offline
post #20 of 20 Old 09-18-2011, 11:27 PM
foggybottombob
It's a "fluid dynamics" physics phenomena. But I still say the effect of the fan on blocking air flow through the radiator is negligible at high speed regardless of the fan speed.
foggybottombob is offline
