Running hotter on highway - JeepForum.com
post #1 of 20 Old 09-16-2011, 08:18 AM Thread Starter
bamasteeler
Round town the cj runs usually about mid range on factory gauge. Get up on highway and within few minutes cruising at about 55-60 my temp indicates upper range of gauge. I'm thinking waterpump isn't able to circulate coolant efficiently at higher rpm's. At first I thought maybe t-stat not opening enough but think that would be evident even around town driving. My plan is to change both t-stat and water pump if I go to change anything since I am in that area. Was wondering if anyone else ran into this issue and maybe what it was on your cj. Thanks
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #2 of 20 Old 09-16-2011, 08:31 AM
lucdog
1980 CJ5
Is there a spring in the bottom radiator hose, it could be colasping at sustained higher RPM's. I think I'd check first.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 20 Old 09-16-2011, 09:04 AM
Foundrydude
Collapsing hose is a good thing to check for, and if it's got a fixed fan instead of a clutch the fan may be blocking airflow.
If you got a dirt track racer buddy helping tune it and locked out the mechanical advance and vacuum advance, that'll cause highway heatup too! So be sure it's not stuck from corrosion either.
good luck!
Foundrydude is offline
post #4 of 20 Old 09-16-2011, 09:12 AM
jblue1555
1979 CJ7
If your still running hot after all that take the rad to a shop and have them flow check it or pull the tanks and rod it out. Running hot at highway speeds usualy is due to low flow.
jblue1555 is online now
post #5 of 20 Old 09-16-2011, 11:58 AM Thread Starter
bamasteeler
Bill
Yes it is a reinforced hose, a gaites flexible hose that is very stiff not the 5 dollar one from parts store lol believe the spring is made into the hose and surrounded by the rubber
1980 Jeep CJ7
1999 XJ CLASSIC
post #6 of 20 Old 09-16-2011, 12:01 PM Thread Starter
bamasteeler
good luck!
Yes the fan is fixed no clutch on this.
What are you suggesting I check to see if it's stuck from corrosion??
1980 Jeep CJ7
1999 XJ CLASSIC
post #7 of 20 Old 09-16-2011, 12:43 PM
Bakunin
Bakunin's Avatar
nah
The clutch fans disengage at speed, so they aren't taking HP and only spin at the rate of airflow coming through your radiator.
Bakunin is offline
post #8 of 20 Old 09-16-2011, 12:50 PM Thread Starter
bamasteeler
Yeah I don't have a clutch fan type, got a straight fan
1980 Jeep CJ7
1999 XJ CLASSIC
post #9 of 20 Old 09-16-2011, 01:12 PM
aero mech
aero mech's Avatar
1980 CJ7
I suffered from the same problem after the last rebuild. i replaced my two core with a three core for a cj with a 304 from autozone. problem solved. jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #10 of 20 Old 09-16-2011, 01:13 PM
lucdog
1980 CJ5
Inside the distributor, the advance mechanicals.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 20 Old 09-16-2011, 02:59 PM
SleeperCJ
1983 CJ7
I had the same problem on my 258 after it was rebuilt. I never dealt with it though since I didn't drive it on the highway much and have since swapped motors and radiators. The cause I suspect was that with the motor rebuild there was less slop between the pistons and cylinder was so the friction at higher sustained rpm caused more heat. If your pump is not malfunctioning you may need to employ some other means to increase cooling, bigger radiator, remote oil cooler, loovers to increase air flow out
SleeperCJ is offline
post #12 of 20 Old 09-16-2011, 09:01 PM
twmattox
How confident are you in a 30-year old gauge? I would at least get an IR thermometer and do some checking of the thermostat housing. I know on one of my other Jeeps, factory gauge showed an 80* temperature swing when the actual temp went from 190 to 205...
twmattox is offline
post #13 of 20 Old 09-18-2011, 01:53 PM
Foundrydude
Fixed fan will block airflow on a vehicle with lots of grille area at highway speed. Most people think the disengagement is just for power/mileage but when the air is already moving 60mph a fixed fan will slow it down if you've got oversize tires or an overdrive transmission to slow the engine speed. Vehicles with fixed fans are designed to run 3000rpm and up on the highway. If you've modernized to a point it's turning a sane RPM at highway speed then the fan should be modernized too.
Be double sure the distributor advance is not sticking before spending money chasing overheating.
good luck
post #14 of 20 Old 09-18-2011, 04:16 PM
Max-Q
1983 CJ7
Your fixed fan is causing the airflow to slow at highway speeds. As the guy above said, say your motor is only turning 2,000 rpms on the highway. The airflow at say 70 mph is greater than the pull of the fan blades at that point. The fan is now creating a barrier which is blocking the higher velocity air from flowing across the radiator.
You need to get a fan clutch.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #15 of 20 Old 09-18-2011, 05:49 PM
foggybottombob
I'm not buying this at all.
When you are driving at speed, the fan can be not turning at all, turning slow, turning 2 times slow or turning really fast and the air flow change through the radiator will be negligible. I have an electric 2 speed fan that I can turn on hi, low or off and it makes no difference in coolant temp when you are driving fast. The no clutch fan will add a little more drag on your engine at high rpm but I would guess that factor is less than 5 horsepower.
Now if you are getting detonation (pinging) your engine will definitely heat up really fast at high speed. You might try some higher octane gas for a tank.
foggybottombob is offline
