Rugged Ridge heavy duty steering kit, reviews? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rugged Ridge heavy duty steering kit, reviews?
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 03-13-2015, 12:05 AM   #1
Cutlass327
Cutlass327's Avatar
1978 CJ5
Looking at this, is it worth the money??
http://www.amazon.com/Rugged-Ridge-1...productDetails
I am upgrading to WT axles, and want to start with new parts...
Already getting MOOG balljoints, will put in new Spicer u-joints, and swap on my 78's knuckles for the 6 bolt hubs and brake parts...
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 06:20 AM   #2
peters
1946 CJ3A
Likely, true DOM is friggin expensive and strong, plus all the leg work is done and it comes with ends. seems legit
peters is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 06:30 AM   #3
orange150
1982 CJ8
I've got it on mine, very beefy. Came as advertised with everything I needed. I would recommend it as an easy steering upgrade.
Edit: I will say though you will have to figure out a new way to mount your steering stabilizer. I'm currently not running one because I just haven't gotten that far yet...
'82 CJ-8
258/T5/D300
AMC 20/D30
orange150 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 07:25 AM   #4
thirstybob
I have it as well. Looks much beefier than stock and no issues.
thirstybob is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 08:16 AM   #5
j33pman
I run this setup also. Much stronger than the stock tie rod drag link combo
Bill H. - 1984 CJ-7
Now with Fiberglass!
My Rebuild thread
http://www.schohariecountyjeepclub.org
j33pman is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 09:20 AM   #6
dirtdudeaz
1983 CJ7
If you had a welder, you can build your own for a little cheaper. I went this route.
I got the bungs/nuts from Speedwaymotors ($10 per bung; 4 needed, and $2 per nut; 4-8 needed). The metal I got from the local steel shop (1-1/4 OD DOM (1" ID)) for about $70, and then the tie rods were Moog. So I guess it was about $120 minus the tie rod ends. I went with the stock 11/16 size TRE's, and MOOG seem to be plenty strong in that size, so I didn't feel the need to go larger.
Some guys on here also use the bigdaddyoffroad parts too.
http://www.bigdaddyoffroad.com/produ...products_id=67
While you are there, you may also consider doing the tie rod flip. Not trying to tell you how to spend your money, but it helps with clearance and corrects steering arm angles if you have any sort of lift. For this, I went with the goferit kit.
dirtdudeaz is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 10:13 AM   #7
skizriz
1978 CJ7
The one thing I didn't like about my RR setup was that the ends have metric threads. Other than that its a beefy setup.
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 10:18 AM   #8
Jim1611
Jim1611's Avatar
So if you need to replace the rod ends the factory ones won't fit.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 01:56 PM   #9
skizriz
1978 CJ7
Nope. Need to buy them from RR. I learned when I bought some 7/8" (or was it 3/4?) ends, and they wouldn't thread in. Checked the thread count, and sure enough, it's different.
Unread 03-13-2015, 02:22 PM   #10
j33pman
This is the only drawback I have found to this setup, but how often do you really change tie rod ends?
Bill H. - 1984 CJ-7
My Rebuild thread
Unread 03-13-2015, 03:24 PM   #11
Jim1611
Jim1611's Avatar
Under normal use you won't change them often. My thinking is that I'd rather be able to go to the local parts store and buy what I need. Suppose it's Saturday and you broke one the day before. You could get the factory style one at the parts store but if you used the RR assembly you can't. Unless the parts store can cross reference the broken one and has it. I just like the idea of easy to get parts.
My build thread
Unread 03-13-2015, 03:28 PM   #12
Erik719
Erik719's Avatar
1983 CJ7
Could you re thread it?
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 05:12 PM   #13
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
I find it hard to believe they would make their own specific ends. I would bet they are a toyota application (possibly FJ80) as that is a common upgrade in those circles and they are metric thread. Does anyone have a RR end they can snap a pic of.....just curious if they have a brand stamped on the top.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 05:33 PM   #14
skizriz
1978 CJ7
I have some RR ends, and some big GM ends, I'll go get some pictures for comparison.
Here's what I found. A what I believe to be a YJ end will fit the RR rods. 11/16 and not metric ????
RR end...
YJ(?) end...It will thread in, I tried it.
Big GM end....Kind on hard to see, but .86 and some change.(if I remember correctly)
Puny stock CJ end...
Unread 03-14-2015, 01:04 AM   #15
streetpro
Observing GIC
streetpro's Avatar
1978 CJ7
Thanks boots are crap, cracked to hell in a year. Stout rod that took a hard shot though.
streetpro is offline   Reply With Quote Quick reply to this message
