Rubicon express lift - JeepForum.com
post #1 of 21 Old 06-25-2014, 07:42 AM Thread Starter
Megaram
Has anyone removed a rear leaf from the rubicon express 4.5" kit? Just got it installed and the back sits around 3/4" higher than the front. The shackles are angled toward the front so you can tell there just isn't enough weight to push the springs flatter. Lookin for a way to remedy this and have seen where people remove a leaf. Just wondering if it matters which leaf of the pack you remove. Thanks guys for any insight.
Megaram is offline
post #2 of 21 Old 06-25-2014, 07:55 AM
Mike Romain
Fill up the gas tank and add some gear or passengers. Springs also settle in after use. If you make it level now, it will be dragging its tail later.
Mike
Mike Romain is offline
post #3 of 21 Old 06-25-2014, 08:16 AM Thread Starter
Megaram
Good advice, didn't think about that. Thanks.
Megaram is offline
post #4 of 21 Old 06-25-2014, 08:50 AM
RenoF250
I agree. I have the opposite problem. My Black Diamond springs sit lower in the rear and seem to be going lower. I am thinking of adding a leaf from the old factory packs.
RenoF250 is offline
post #5 of 21 Old 06-25-2014, 04:04 PM
mvbrady
agreed....take it wheeling and flex her out,
she will settle some.
you may need to trim the rear corners a little to allow for full flex
without damaging the body.... just something to watch for.
mvbrady is offline
post #6 of 21 Old 06-25-2014, 04:22 PM
AlexThePhotoGuy
Judging from the pics, it looks like you're stuck in your garage.
AlexThePhotoGuy is offline
post #7 of 21 Old 06-25-2014, 06:56 PM
Kastraelie
1977 CJ7
Wait wait wait....
If I take out a leaf from all 4...will this lower my ride? I mean yeah, I can see how it would make the spring softer and more likely to compress...but does removing a leave actually lower it without this effect?
If so that is awesome. I would love to lower my ride about an inch or so to help my geometry problems.
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
Kastraelie is offline
post #8 of 21 Old 06-25-2014, 09:28 PM
spottedfrog
1979 CJ5
I suspect those leaves will settle quite a bit looking at the shackle angles, both front and rear. Also judging buy the height of the frame over those 33's. either that or your Jeep weighs nothing.
spottedfrog is offline
post #9 of 21 Old 06-26-2014, 07:17 AM
83vert
1982 CJ7
I'm in the same boat, I hope mine settle as well.
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #10 of 21 Old 06-26-2014, 08:26 AM Thread Starter
Megaram
Haha, I thought so too, but got the brakes bled and backed it out real slow and it clears by just a little!
Megaram is offline
post #11 of 21 Old 06-26-2014, 08:28 AM Thread Starter
Megaram
Originally Posted by mvbrady
agreed....take it wheeling and flex her out, she will settle some. you may need to trim the rear corners a little to allow for full flex without damaging the body.... just something to watch for.
Ten four, I live on the gulf coast so there ain't much rock crawling goin on, but I'll take it to the the beach and try to hit as many dunes as possible. I don't think I'll get up into the wells too much with my type of drivin.
Megaram is offline
post #12 of 21 Old 06-26-2014, 08:31 AM Thread Starter
Megaram
I'm hopin so. The jeep isn't real heavy back there, just usually a couple kiddos and maybe an ice chest. Eventually I'm gonna put a tire carrier rear bumper so that should add some weight.
Megaram is offline
post #13 of 21 Old 06-26-2014, 08:35 AM
capt205
1983 CJ7
The 4.5 on my 83 CJ7 took about a year to settle. It is not DD, and I've only had it in the woods a couple of times. I thought the same thing as the OP, but settled a little at a time...now its all good.
capt205 is offline
post #14 of 21 Old 06-26-2014, 08:42 AM
1949er
1949er is offline
post #15 of 21 Old 06-26-2014, 08:58 AM Thread Starter
Megaram
That's reassuring, I'm gonna take that route as well. Just let it play out. How do you like the ride of the lift, did you use their shocks as well?
Megaram is offline
