rubber mount bushings - JeepForum.com
post #1 of 22 Old 04-04-2009, 06:57 AM Thread Starter
hold24
1977 CJ7
I need some help installing my rubber body mounts. I have a 78 cj7 and I bought the rubber bushing kit from crown. I can't figure out the two front frame mounts. they are a smaller hole. Any pics would be helpful. I ran the search and could'nt find any info. Plus where do the larger donuts go.
1978 cj7 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac...
1979 cj7 Cumberland green Golden Eagle 18k Original miles V8 auto..100% rust free Oregon Jeep..
hold24 is offline
post #2 of 22 Old 04-04-2009, 12:39 PM
keith460
Jeep. There's Only One
keith460's Avatar
Before you install the body bushings, you must cut down the metal sleeves to size. About 1-3/8" total length or 1-1/4" length form sleeve washer to end of tube. You do not want the metal sleeve to protrude below the bottom rubber isolator or the body mounts will not compress correctly. Without cutting the tubes to length, the body won't be fastened tight enough against the frame and you run the risk of the tub shifting around a bit. All body mounts, #2-#7 get torqued to 24 ft/lbs and #5a and the front grill get torqued to 36 ft/lbs. #5a is the mount that is located above the gas tank and is bolted to a bracket off of body mount #5.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 22 Old 04-04-2009, 09:57 PM Thread Starter
hold24
1977 CJ7
Thanks. that helps alot...but does # 2 have a bushing that actualy fits in the smaller hole in the frame mount?
hold24 is offline
post #4 of 22 Old 04-05-2009, 05:54 AM
keith460
keith460's Avatar
I believe the hole you are referring to is the one that was used in the welding jig when the frames are built. Those holes that are smaller and either round or hex shaped were used to align the brackets as they were welded to the frame.
The actual hole for the body bushings should be about 1-1/4" I.D. and that smaller hole for the jig is about 9/16".
1984 CJ-7 Renegade
keith460 is offline
post #5 of 22 Old 04-05-2009, 06:30 AM
Mike Romain
I was under the impression that the fat rubber isolator goes on the #5 mount by the fuel tank. That is where the hardest up and down effect happens, especially if you have a load on.
Mike
Mike Romain is offline
post #6 of 22 Old 04-05-2009, 07:57 AM Thread Starter
hold24
1977 CJ7
I'm talking about the actual hole for the rubber bodymount is smaller in position 2 than all the others. Maybe because it's a 1978 frame? I'm confused. where did you get your grill mount bushing? They do not come with the crown kit?
hold24 is offline
post #7 of 22 Old 04-05-2009, 08:10 AM
Mike Romain
There is a special kit for the 76-79 CJ's, it isn't the same as for the 80-86's. Did you get the correct kit?
Mike
post #8 of 22 Old 04-05-2009, 08:30 AM Thread Starter
hold24
1977 CJ7
Maybe I did'nt...I did not see any others offered. Where can I get one?
hold24 is offline
post #9 of 22 Old 04-05-2009, 08:42 AM
FLBOY
If you bought the wrong one, And need to order another. I,m looking to buy the kit for an 84 CJ 7 right now.
It,s better to be stuck , Than to have chickened out and went home
FLBOY is offline
post #10 of 22 Old 04-05-2009, 09:06 AM
Mike Romain
Here is one place: http://www.quadratec.com/products/26057_11.htm
Mike
post #11 of 22 Old 04-05-2009, 09:20 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
Not trying to hijack, But what is the difference between the two? My jeep is a little mixed up and want to get the correct kit.
Thanks,
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #12 of 22 Old 04-05-2009, 09:23 AM
Mike Romain
Thanks,
Jeff
Just to take a wild guess, #2 mount is a different size for one thing...
Mike
post #13 of 22 Old 04-05-2009, 09:34 AM
keith460
keith460's Avatar
When I tore down my 84' CJ I marked each original body bushing per location and the #2 had the larger isolator on that bracket. The #2 body bracket is really the only one that has room to fit the larger isolator anyway. You also need to get a larger flat washer for that one too. All washers are 2"O.D. x 3/8" I.D. and the two for the larger isolator are 2.5"O.D. x 3/8" I.D.
keith460 is offline
post #14 of 22 Old 04-05-2009, 09:38 AM
Mike Romain
The fat rubber and large washer fit just fine in front of the tank on mine, just put them on recently.
Mike
post #15 of 22 Old 04-05-2009, 10:10 AM
yellow85cj
Mike - while it may have fit fine, if you look at the parts manual diagram you will see that Keith is correct that they are for the #2 mount.
Part #13 for the #2 spot and #14 for the rest.
Currently in pieces - all of them
yellow85cj is offline
Rubber bushings between crossmember and frame rail? Coiz Jeep CJ Forum 2 09-27-2008 03:49 PM
Body Mount Rubber cj5jeff Jeep CJ Forum 2 06-24-2008 10:04 AM
Best way to remove rubber bushings Mike78cj7 Jeep CJ Forum 10 05-27-2007 08:05 AM
replace bushings? Old worn out rubber things?? dblock16 Jeep CJ Forum 1 04-01-2007 07:09 PM
Motor mount rubber? mideerhunter Jeep CJ Forum 2 01-02-2006 06:43 AM
