RPM's @ 70 mph ? - JeepForum.com
post #1 of 21 Old 03-12-2014, 04:04 PM Thread Starter
1bucknrut
1978 CJ7
RPM's @ 70 mph ?
cj7 with quadratrac & TH400 auto trans, 3.54 gears with stock 304 pushing 33 x 12.5 tires, My rpms run at 3000 rpm at 70 mph, That seems high to me but wanted to ask if that's normal since its a quadratrac, I've owned it for 15 years but never driven it over 30 since it was my hunting rig,
Thanks Buck
1bucknrut is offline
post #2 of 21 Old 03-12-2014, 04:11 PM
UBERK
1976 CJ7
Sounds a bit high...
UBERK is offline
post #3 of 21 Old 03-12-2014, 04:16 PM
skizriz
1978 CJ7
Is your speed going by GPS? With the tires, your speedo will be off. Mine will run at about 2,200 at 60 mph. I had the same setup, with 35" tires.
skizriz is offline
post #4 of 21 Old 03-12-2014, 04:17 PM
yellow85cj
Are you sure you were doing 70? If the speedo gear was not changed with the larger tires, the speedo would be incorrect.
Currently in pieces - all of them
yellow85cj is online now
post #5 of 21 Old 03-12-2014, 04:32 PM
Stormpaw
1983 CJ7
I don't know anything about automatic transmissions or the Quadratrac, but Novak has some useful calculators. It seems like you should be reaching 70mph around 2500rpm.
Of coarse, your speedometer will be off if you did not change the driven gear in your transfer case to match your tire and axle gear ratio combination.
Stormpaw
My CJ7 and I are partners. I do my best to keep it running and it does its best to get me were I am going. Unfortunately, we both sometimes fail....
Stormpaw is offline
post #6 of 21 Old 03-12-2014, 05:00 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
http://www.grimmjeeper.com/gears.html
The ultimate gear calculator.
"In the end...It's all Hack."
HackFabrication is offline
post #7 of 21 Old 03-12-2014, 05:50 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Tell me more of this 70 MPH thing???
I think I may have heard of it.
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #8 of 21 Old 03-12-2014, 07:56 PM
LumpyGrits
What are you using to tell you that you are doing 70 mph?
Because I'll bet you ain't at 70.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #9 of 21 Old 03-12-2014, 08:38 PM Thread Starter
1bucknrut
1978 CJ7
Ok I didn't change the speedo drive gear so the gauge wouldn't be correct, so I took my gps liked skiwiz inquired about and this is what I have
gps 65 mph gauge 58 rpms 2500
gps 70 mph gauge 63 rpms 2700
gps 80 mph gauge 70 rpms 3100
So does this sound liveable if not what would be your recommendations to lower the rpms at those speeds, Not that im going to be driving it 80 but 65-70 on semi basis
UBERK on that chart what speed is calculated at ?
I will be changing out the gear on the speedo soon
Buck
post #10 of 21 Old 03-12-2014, 08:47 PM Thread Starter
1bucknrut
1978 CJ7
Could you clarify your response
post #11 of 21 Old 03-12-2014, 08:50 PM
holliewood61
1981 CJ7
I would be tickled pink with that. for some reason according to my tach with my th400/d20 combo with 3.54's on 35's im turning about 2850 at 55 mph
holliewood61 is offline
post #12 of 21 Old 03-12-2014, 09:02 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
srsly?
It was a joke..
If I ever hit 70, it would be like a Delorean at 88
Truck633 is offline
post #13 of 21 Old 03-12-2014, 09:08 PM Thread Starter
1bucknrut
1978 CJ7
Well holliewood61 that are some words of encouragement on my end
Buck
post #14 of 21 Old 03-12-2014, 09:14 PM Thread Starter
1bucknrut
1978 CJ7
srsly?
It was a joke..
I thought that might have been the case after I thought about it a minute, no harm no foul
Buck
post #15 of 21 Old 03-13-2014, 02:33 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Buck
Buck,
Something is a little off with those numbers. The percentage difference between GPS speed and gauge speed should be the same at all speeds.
That said, your engine should be quite comfortable at 2500 RPMs. A slightly larger tire would lower the RPMs some, but would also lower the power and mileage. I think you're about right where it's at.
Matt
Matt1981CJ7 is offline
