Round tail lights? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Round tail lights?
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsDisc Brake Kits from ECGS
Unread 11-27-2012, 07:27 AM   #1
RustyNutts
Round tail lights?
I have busted up tail lights that need replacing. They are the stock replacement lamps and everything works except both plastic shells are cracked and have missing sections.
Moving a CJ that has no rear axle with a tractor bucket and chains has its disadvantages, I've learned.
My rear spot light is round, the gas cap is round, the front lights are all round, so I'm thinking of using round rear lights.
The tranny mounted reverse light switch is not working, so I use the rear spot when I'm backing up and need light. (Farm Jeep mostly)
any thoughts, and were any older Jeeps fitted with round rear lights?
just curious and thanks for any replies.
RustyNutts is offline   Reply With Quote
Unread 11-27-2012, 07:34 AM   #2
CSP
'75 and older CJ's had round tail lights. Good luck finding originals if that's what you're after.
CSP is offline   Reply With Quote
Unread 11-27-2012, 07:45 AM   #3
shooters_7
This is what I put on my CJ7. No drilling as they use two of the three holes that hold the "boat" trailer lights.
http://www.quadratec.com/products/13107_400.htm
Pic of them installed.
shooters_7 is offline   Reply With Quote
Unread 11-27-2012, 11:29 AM   #4
roadhog304
1973 CJ5
I have the same lights as shooters 7. They are super bright and work well.
1973 Jeep CJ5- AMC 360, T181B, Scout Dana 300, Dana 30 Truetrac, Dana 44 Detroit Locker
roadhog304 is offline   Reply With Quote
Unread 11-27-2012, 02:52 PM   #5
sarfu
1974 CJ5
Grote makes exact replicas for the early cj's, I have them on my '74, wuill have to get a part number.
sarfu is offline   Reply With Quote
Unread 11-27-2012, 03:06 PM   #6
scottg73
1979 CJ5
What about the license plate light?
scottg73 is offline   Reply With Quote
Unread 11-27-2012, 05:29 PM   #7
brownbagg
1930 MK Compass
truck stop, get some led ones.
brownbagg is offline   Reply With Quote
Unread 11-27-2012, 06:55 PM   #8
roadhog304
1973 CJ5
My licence plate is mounted to my gas tank skid so I did not worry about a licence plate light on the tail lights. one of these days i am going to do what brownbagg suggested or get me some of those lighted bolts.
Unread 11-27-2012, 07:02 PM   #9
shooters_7
I bought the lighted bolts. Haven't put them on yet as I know all the cops here and they let me off.
Unread 11-27-2012, 10:20 PM   #10
Alex77cj7
1977 CJ7
dd mine myself.. bought the lights from pepboys for cheap. came out great. also, these are completely recessed and a lot cheaper than those other ones above..
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline   Reply With Quote
Unread 11-28-2012, 07:53 AM   #11
RustyNutts
Update: Went to Oreilly's after work yesterday and looked at their offerings. They actually had lights that were listed as JEEP, and they were stock looking for 17 bucks each. Bought two.
I saw the recessed LED's and when I get around to doing my rear corners, I'll cut the tub and put those in. They were only $19 each.
Since I do run on the road some, I am going to just throw these stockers on there and be legal for now.
Thanks for the replies.
Unread 11-28-2012, 08:16 AM   #12
texasdave
texasdave's Avatar
1980 CJ7
Just for future reference each tail light has a DOT number stamped on it. You can always cross reference that number in a parts store.
texasdave is offline   Reply With Quote
Unread 11-28-2012, 11:12 AM   #13
dnjeep
1976 CJ5
Here's what I used: Semi-trailer tail lights. And for the license plate I used motorcycle bolt-lights (the ones w/ the light inside the bolt)
dnjeep is offline   Reply With Quote
Unread 11-28-2012, 01:25 PM   #14
scottg73
1979 CJ5
The license plate is so ugly I couldn't see anything else.
Unread 11-28-2012, 05:18 PM   #15
papa355
1977 CJ7
lol that's funny right there.
1977 CJ7, 304 amc, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
"I wouldn't have road rage, If you knew how to drive...."
papa355 is offline   Reply With Quote
