Rough idle, carter bbd - JeepForum.com
post #1 of 4 Old 11-09-2011, 10:31 PM Thread Starter
dtcohen
1980 CJ7
So i have a 258 with a carter bbd on it. It does pretty good most of the time, but sometimes after driving for a while it will idle really rough and sometimes stall. If I turn the engine off and restart it, it idles fine. Any ideas what is going on?
dtcohen is offline
post #2 of 4 Old 11-10-2011, 07:12 AM
sjdano
As I'm sure you've noticed, the Carter BBD has a ton of what most believe to be a bunch of extra junk attached to it. I'll spare you the technical list of parts and features and say that most are prone to failure at some point or another.
Those with the BBD also have a "computer" to help manage the function of the carb in efforts of maintaining fuel delivery. While you MAY get better mileage with the BBD, with it functioning correctly, on a stock or nearly stock CJ, it's not that much better.
There's a number of write-ups around on how to trouble shoot the BBD and even correct/repair some of the failure points. I think most that have been there, done that will also agree when I say, don't bother!
Rather than trying to fix it, long term you would be better off just ditching it for another carb. The most popular choices I've seen over the years include:
Motorcraft 2100 (Very Holley like)
Holley 2bbl (350 CFM version - looks very similar to the Motorcraft, more adjustable and user friendly)
Webber
I could go on and on about this one, but I'll stop here unless you're interested in knowing more. For the money I've spent trying out different carbs, I could have been half way to a fuel injected chevy 5.3L swap!
sjdano is offline
post #3 of 4 Old 11-10-2011, 07:20 AM
SkyJax
1978 CJ5
Search "clogged idle tubes". That solved my problem.
SkyJax is offline
post #4 of 4 Old 11-10-2011, 04:41 PM
86cj74.2L
86cj74.2L's Avatar
Most BBD equipped jeeps are not daily drivers. Saying that when the gas evaporates it always crap behind. When enough builds up it will get sucked in the metering circuits.
I wish I had a picture of the rear float bowel on the holly out of the Chevelle. 1/8 inch of sediment. When I'm done driving Chevelle I remove a bottom screw in rack bowel and drain gas out. Unfortunately u can't do that on the BBD. You could clamp the fuel line shut and run the carb out of gas though.
86cj74.2L is offline
Carter BBD#2: won't idle when warmed up 82CJ_Chemist Jeep CJ Forum 12 09-03-2010 08:24 PM
carter bbd need curb idle IBGRMPY Jeep CJ Forum 2 10-19-2009 03:50 PM
Carter Idle Curse 1984CJ Jeep CJ Forum 8 08-25-2006 09:17 PM
Carter Idle ClarkGriswold Jeep CJ Forum 0 06-29-2006 07:30 PM
84, Carter POS won't idle AeroViper1 Jeep CJ Forum 31 04-14-2005 04:58 PM
