Rough Idle - JeepForum.com
post #1 of 4 Old 01-06-2009, 10:41 PM Thread Starter
dbd
1979 CJ5
Rough Idle
Hi Guys,
I am stuggling with a rough idle problem on start up, a 258 with a team rush upgrade, any how, once it comes off fast idle, she barely keeps running, not smooth, have checked vac leaks, replaced carb base plate gasket, replaced fuel filter, new carb.....
does anyone have any suggestions, would be nice if she ran like a normal carberated motor..... guess that may be an oxy moron....
thanks much
dbd is offline
post #2 of 4 Old 01-07-2009, 05:42 AM
cb_cooke
do you have a fuel filter inline that has 1 in and 1 out? or 1 to 2?
i had the same thing and looked in the manual
it showed the positioning of the 1 to 2 (like mine)
I had the side with the 2 positioned so that there was one coming out the middle and other on bottom
like this
I simply loosened the clamps a tad, and twisted the filter to make the side with 2 have one in the center and the other above that, or on top of the other.
that seemed to do the trick.
Freedom is not free.
USN ret. 1987-2008
Now I'm livin' the Jeep lifestyle...it only stings a bit !
cb_cooke is offline
post #3 of 4 Old 01-07-2009, 06:05 AM
keithf
1983 CJ7
Idle tubes. This worked perfect for me.
http://www.jeeptech.com/engine/carter.html
I am going to look into a rebuild kit that has shorter tubes and screens that cover the ends so they don't get clogged. I also pulled the top of the carb off rather than take the butterflies out.
Keith
keithf is offline
post #4 of 4 Old 01-07-2009, 12:29 PM
80cj
80cj's Avatar
1980 CJ5
About a year ago mine was doing the same thing. Come to find out, the manifold bolts were all loose. A few minutes with a torque wrench fixed my problem.
80cj is offline
rough idle Hank86 Jeep CJ Forum 18 08-16-2008 11:17 AM
Help Me/ Rough Idle armoroffroad Jeep CJ Forum 4 04-29-2007 08:07 AM
rough idle with a TFI mod,what up with that?? Mr.Crowley Jeep CJ Forum 4 03-25-2007 06:51 PM
rough idle a_wild1 Jeep CJ Forum 4 06-01-2004 12:36 PM
rough idle texstar99 Jeep CJ Forum 2 07-14-2003 09:48 AM
