rough idle - JeepForum.com
post #1 of 3 Old 07-13-2003, 03:08 PM Thread Starter
texstar99
rough idle
The idle on my 83 CJ7 258 became rougher and rougher over the last few months to the point I cold not drive it. I replaced the Carter BBD carb with a rebuilt and the jeep ran wonderfully for 24 hours. Today the same old rough idle is back and I barely got it home. I've rechecked the timing, vaccum lines, and connections. The idle mixture screws are out so far they look like they'll fall out of the carb base. When I try to turn them in to an acceptable setting the engine stalls. Then, magically, the engine idles perfectly. I re-adjust the idle speed and idle jets and I jump in and test drive it and it'll run okay for a mile or 2, then we're back to undriveable. It seems to be in a control module or something. There will be a very slight click behind the carb (like a relay or solenoid click) and the idle and engine become rough and eventually stalls. Someone please help. I've disconnected all the vaccum hoses and plugged them off with no improvement. Any ideas?
texstar99 is offline
post #2 of 3 Old 07-14-2003, 09:23 AM
xxxflhrci
xxxflhrci's Avatar
Re: rough idle
As harsh as this sounds, trash the Carter and get a Weber Kit. I had the same problems with the Carters and could never get it to run just right. I spent 300 bucks on the Weber kit and have never been happier. Easy to install. Factory adjusted. Made great power. Gas mileage improved. Sounds great. Sound like it it gonna suck the hood off the hinges.
xxxflhrci is offline
post #3 of 3 Old 07-14-2003, 09:48 AM
rustyCJ
Re: Re: rough idle
read this
if like me and dont have $300 to throw at your jeep at a whim then try this. it is a hella lot cheaper then buying a new carb to replace the rebuilt one you just bought and will prolly fix your problem if you can do it.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
Rough Idle dbd Jeep CJ Forum 3 01-07-2009 12:29 PM
rough idle Hank86 Jeep CJ Forum 18 08-16-2008 11:17 AM
Help Me/ Rough Idle armoroffroad Jeep CJ Forum 4 04-29-2007 08:07 AM
rough idle with a TFI mod,what up with that?? Mr.Crowley Jeep CJ Forum 4 03-25-2007 06:51 PM
rough idle a_wild1 Jeep CJ Forum 4 06-01-2004 12:36 PM
