Rough country shackles - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rough country shackles
Oconee Off-Road Free Shipping Lifts Tires Bumpers Tops andAdvance Adapters SYE KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-07-2013, 08:49 PM   #1
Blakescj7
I recently bought my first cj7 jeep and I noticed the shackles on the front are bent. I saw rough country has boomerang shackles, has anyone used these and are there any advantages to using them over standard ones?
Blakescj7 is offline   Reply With Quote
Unread 09-07-2013, 10:30 PM   #2
Spieg8
1984 CJ8
As I understand it, the major reason for boomerang shackles is they are supposed to help prevent the shackle from inverting (pivoting inward toward the axle rather than outward). I suppose it can't hurt anything to go with that style, but I can honestly say that in 40+ years of Jeeping, I've yet to see a shackle inverted in person. The main thing I look for is strong construction (something that won't bend like the ones you have now). I like them to be made with 3/8" thick stock and a welded cross-brace. Greaseable bolts are also a big plus.
Spieg8 is offline   Reply With Quote
Unread 09-07-2013, 10:53 PM   #3
Blakescj7
Yeah I've never seen one invert either. They don't look bad at all and are pretty affordable. I know some people arent fans of rough country products but ive never seen anything wrong with their products.
Unread 09-09-2013, 10:18 AM   #4
pagnani
1983 CJ7
I think the YJ guys need the booms. Once you go with a lift spring on a YJ there is more of a tendency for the shackle to invert. The booms prevent this. On a CJ they are not really necessary unless they have the look you want.
83 CJ7 D44 rear, 4.56, 4" YJ lift, 33" MT, Warn bumper, XRC-8, LOD TCarrier, PS Sliders
"In-4-LO"
pagnani is offline   Reply With Quote
Unread 09-09-2013, 10:23 AM   #5
rplivin
Check out the Crabtree shackles. Jim is a member and his stuff is second to none in quality also USA made. His shackle kits comes with everything you need.
rplivin is offline   Reply With Quote
