rough country lift kit questions - JeepForum.com
post #1 of 23 Old 08-03-2009, 04:45 AM Thread Starter
zombiesmasher13
I'm going to be getting a 4" lift kit for my 81 cj7. The rough country kits seem like a pretty good kit for the money.
Any issues I should expect? Are they decent kits?
zombiesmasher13 is offline
post #2 of 23 Old 08-03-2009, 06:00 AM
Slydeco
I,ve got a 4" lift and it rides great ,They get a bum rap here but I have no complaints
Slydeco is offline
post #3 of 23 Old 08-03-2009, 07:06 PM
4WheelingPlus.c
1988 XJ Cherokee
We sell lots of the Rough Country 4" lift kits. They are very decent especially for the price and their great customer service. I deal with many companies on a daily basis and Rough Country always has some of the best customer service IMO.
One big note that I tell all of my customers that lift an older Jeep: Keep in mind that your stock springs have likely sagged and the new 4" lift springs are designed to give you 4" more than a new stock spring. In other words if your stock springs have sagged 1" over time you will end up with around 5" of lift when add new 4" springs. It's not an exact science by any means but I have had more than one customer state that they were "surprised" how tall their Jeep was after lifting it only 4" and adding bigger tires.
Thanks,
Ron Dunn Jr
4WheelingPlus.c is offline
post #4 of 23 Old 08-03-2009, 07:49 PM
HondaSkidoo
I have the 2 1/2" RC Lift on my 78 CJ for about 6 years know with no problems and it rides great. Good Luck
HondaSkidoo is offline
post #5 of 23 Old 08-03-2009, 08:48 PM
4WheelingPlus.c
1988 XJ Cherokee
I almost mentioned the 2.5" lift as it is a very popular lift for the CJ's but I didn't want to "sway" zombiesmasher13 away from the original plan to get the 4"
Thanks,
Ron Dunn Jr
post #6 of 23 Old 08-03-2009, 09:51 PM
poppatello
Oh no, we wouldn't want him to spend less money now would we?
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #7 of 23 Old 08-03-2009, 10:16 PM
4WheelingPlus.c
1988 XJ Cherokee
It's only a $30 difference between the two so price rarely is a deciding factor.
It usually comes down to "just how tall" do you want your Jeep to be?
Thanks,
Ron Dunn Jr
post #8 of 23 Old 08-03-2009, 10:27 PM
poppatello
well if I had to do it over again, I would have done the 2.5 lift myself. Unless you really plan on doing some rock climbing, (which I do not) you don't need the 4" lift. The drive angles will stay the same with a 2.5 and you don't normally need a drop pitman arm that you would have to pay extra for, and extended brake lines, and a trans drop kit. It is really cheaper then 30 bucks to go with the 2.5 kit over the 4". Just my .02
Paved Roads
post #9 of 23 Old 08-03-2009, 10:54 PM
4WheelingPlus.c
1988 XJ Cherokee
Very well said! Your feedback is pretty much verbatim to what I hear from most of our 4" CJ lift kit buyers.
Rarely I get a buyer that isn't happy with just 2.5" of lift but we fix their issue pretty quickly with longer shackles. It's much easier to raise your CJ a little more than it is to lower it.
Thanks,
Ron Dunn Jr
post #10 of 23 Old 08-03-2009, 11:24 PM
80cj
80cj's Avatar
1980 CJ5
Depends on what size tires you want to run, doesn't it?
80cj is offline
post #11 of 23 Old 08-03-2009, 11:49 PM
CJfreak
1975 CJ5
With all due respect to Ron, I would go the other way and say I was NOT surprised at how much the 2-1/2" kit lifted my Jeep. True it is not an exact science and it's hard for me to really tell just how much lift I actually got from it, but I thought with the custom slightly longer shackles I made I would see more like 3" lift and I'm not so sure I ended up with more than 2" out of the whole deal. Maybe the scout axle tube diameter stole some of what I expected. I haven't had a good chance to really evaluate the ride yet but I will say it looks quality and the price was good. Do some searching on the forum zombie because I believe I have read of others who questioned the amount of lift they got.
'75 CJ5 w/304/T150/D20/D44's/3.07/33" Thornbirds/Glass Body...
CJfreak is offline
post #12 of 23 Old 08-04-2009, 12:07 AM
4WheelingPlus.c
1988 XJ Cherokee
Did you have the longer shackles installed before or after you installed the new leaf springs?
How did you place the spring perches on the Scout axles? What perches did you use?
Thanks,
Ron Dunn Jr
post #13 of 23 Old 08-04-2009, 03:25 AM
cjbomber
Hey POPPATELLO, How does your jeep run with that 4 banger in it? I have a 4 banger and am thinking of swapping in a 4.0l. I havent seen to many people stick with the 4. Anyone else have anything that would herlp? Thanks Matt
cjbomber is offline
post #14 of 23 Old 08-04-2009, 07:27 AM
poppatello
Well that is another draw back with going with a 4" lift when you have the 4 Cly. I love the motor; love the ride, but when you lift it, what else do you feel compelled to do? Add bigger tires! And the 4 doesn't like that too much. I have 32's on it now, and yes it rides completely different from a 31 to a 32. The only reason I went with 32's is cause they cost me a 100 bucks with the wheels and the wheels were redone the tires were new! I would have jumped right up to a 34x9.5 if I got just the wheels and boy that would have been murder. The jeep crawls over bridges! Doesn't like the sand. If I'm on flat Hwy I can sometimes get her up to 75. Don't really want to go that fast, but just to see if she can do it. I can do 75 up to the bridge and by the time I'm on the peak, she's down to 45! Some say regear, some say swap motors. Like 4 wheeling said, it's a pain to drop down the lift and go smaller tires once you've done it, so I will be doing the 4.2 swap. I would have just done the 2.5 lift and 31's clear them fine and the jeep would be a beast. I just have a tall dog.
Paved Roads
post #15 of 23 Old 08-04-2009, 07:28 AM
poppatello
Another point is the 4 works harder to turn 32" tires Vs the 31's. Just think what the 34 would have done!
Paved Roads
question bout rough country lift jbayliff Jeep CJ Forum 2 04-13-2009 01:53 PM
rough country lift not what advertised? CJfreak Jeep CJ Forum 13 09-03-2008 05:24 PM
rough country lift (new brake lines??) 81 cj 5 Jeep CJ Forum 1 03-29-2007 06:42 PM
Rough Country 4in lift macvsog Jeep CJ Forum 5 01-19-2007 12:59 PM
4" Rough Country Lift Kit certifiablejeep Jeep CJ Forum 3 09-10-2002 05:02 PM
