Rough Country Install Coming Up This weekend - JeepForum.com
post #1 of 28 Old 05-24-2011, 11:13 AM Thread Starter
Blue83CJ7
1980 CJ7
This may turn into my build thread but I stupidly sold my "dream CJ" a few years ago (blue one in my profile) so I am trying to rebuild this clunker into what my old one was, and step one is the lift.
I am not too concerned with the install alone, but I am finding more and more rust and other issues with my jeep, and I am also worried I will need to fix some frame rust, get longer brake lines, driveshafts, wheels tires that I wasn't planning on doing on the short term, as I only drive around the neighborhood until I get alot of stuff addressed.
I hit everything with PB blaster every night this week, and will let you guys know how it goes. I hope I didn't kick the hornets nest on this one, and I hope it works out OK or the wife won't let me get any parts for a long time.
Blue83CJ7 is offline
post #2 of 28 Old 05-28-2011, 11:21 PM Thread Starter
Blue83CJ7
1980 CJ7
First Complaint, and first question:
Complaint: The packaging, aka the stickers, all over the springs are a PITA! Took me about 2 hours to scrape them off with a razor blade, and now I have to keep scraping the sticky off of them and paint them so they don't rust where I scraped a little too hard... I through for a second I might file a claim with UPS for damage or complain to RC, but I doubt either would make a difference, and I wanted to put it on this weekend since I have no other time off in the near future.
Question: Anyone know why I have 4 main (larger) bushing halves with flutes, and 4 without? Do the fluted ones go on the front spring or the back, or did they just screw it up? Instructions say nothing about this...
post #3 of 28 Old 05-29-2011, 05:47 AM
Skerr
Good luck with the install. Test fit all of your bushings. Rear springs are wider than the front, so make sure you accomodate those spring eyes first.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #4 of 28 Old 05-29-2011, 06:36 AM
gojeepin
1983 CJ7
Originally Posted by Blue83CJ7 View Post
... Question: Anyone know why I have 4 main (larger) bushing halves with flutes, and 4 without? Do the fluted ones go on the front spring or the back, or did they just screw it up? Instructions say nothing about this...
The bushing "flange" will be thicker for the front springs. The spring mount on the frame is the same width as the rear but the spring is .5" narrower.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 28 Old 05-29-2011, 07:03 AM
Patter
1981 CJ5
Correct. ^^
Also the fluted bushings should go to the shackle end of the spring. The non fluted should be at the solid frame mount. I think there is a steel sleeve that slides into those? Then the mounting bolts through the sleeves.
Mine had them.
And. I can't really tell by the pics, but. If the wraps on the ends of the springs are different diameters on the o.d.
The bigger one mounts to the frame. Other (smaller) to the shackle.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #6 of 28 Old 05-29-2011, 07:46 AM
Skerr
Exactly! I couldn't think how to say it! Thanks...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #7 of 28 Old 05-29-2011, 08:05 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
Only thing I can recommend is don't over squeeze the bushings at the shackles. I did the exact same lift and the only issue that I couldn't deal with was the rear driveshaft. To fix the problem I rolled the diff to where it pointed almost directly at the Tcase (shimmed at the housing saddles) and had a double cardan driveshaft built. Other than that and the fact that it is rougher than a cob!! I am pretty happy with it. I had one spring relax a little in the rear and the inevitable "Jeep Lean" is slowly coming back, but nothing I can't deal with later!!
Good luck and post "after" pics..
Tom
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #8 of 28 Old 05-29-2011, 08:55 AM Thread Starter
Blue83CJ7
1980 CJ7
Thanks guys... I probably would have figured that out after a few hours of wondering why the bushing's didn't fit, haha. Glad I asked, and thanks for the info.
Going out now to get started
Truck 633 - Do you have narrow track or wide track axles? Yours is exactly how I want mine to look... If narrow track, what backspacing/spacers did you need to fit 35s?
I am ready for the rough ride, I just hope my frame tub & crusty wiring can handle it!
1980 CJ7 - The Grenade
post #9 of 28 Old 05-29-2011, 09:12 AM
johnsom5
Let us know how it all turns out. Got my 4" soft ride lift Friday and, if I have time, might install it this week. Did your kit come with a transfer case lowering kit? Supposedly mine does, but I don't know exactly how it works. Too busy to open up all the boxes this weekend.
johnsom5 is offline
post #10 of 28 Old 05-29-2011, 09:16 AM Thread Starter
Blue83CJ7
1980 CJ7
It did come with a bag of 6 "pucks" to drop the case (loosen all bolts with jack holding the skid the tilt the skid to install side one pucks, then switch), but I am worried that my valve cover will hit the firewall if I lower the tcase with the engine now angled back a little bit more... I remember it hitting on my last CJ, but I had an aftermarket valve cover
Also worried my skid bolts /nut-serts will strip out.
post #11 of 28 Old 05-29-2011, 09:25 AM
johnsom5
Hmmm, I was afraid it involved tilting everything down. Wouldn't that mean the angle coming from the tc to the front dif will be off then and the rear dif will have to be pointed up? I need a new front shaft anyway, but not another excuse to purchase double cardan shafts! Buying a lift, wheels, and tires in one weekend kind of kills the wallet!
Well, get to work, good luck, and try to take some pics.
johnsom5 is offline
post #12 of 28 Old 05-29-2011, 10:47 AM
gojeepin
1983 CJ7
I point this out a lot to folks but I haven't got pictures... only drawings. There's a good example in post #7.
The drop pitman arm is a lot shorter than the stock one.
gojeepin is offline
post #13 of 28 Old 05-29-2011, 12:04 PM
ErikEastman
Looks like your sway bar links are two different lengths??
ErikEastman is offline
post #14 of 28 Old 05-29-2011, 05:23 PM Thread Starter
Blue83CJ7
1980 CJ7
No, that's just the pic. They are the same length in real life :-)
Update coming soon, but anyone know if the longer shocks go in the back or the front?
post #15 of 28 Old 05-29-2011, 05:50 PM
johnsom5
I'm pretty sure the longer shocks go in the rear.
johnsom5 is offline
Rough Country 4" install problem littleturner76 Jeep CJ Forum 118 06-23-2010 08:35 AM
Rough Country 4 inch install FLAWLESS!! Truck633 Jeep CJ Forum 12 04-01-2010 04:13 PM
Anyone install the Rough Country Lifts?? AndyGrogg Jeep CJ Forum 17 06-23-2009 09:19 AM
rough country shocks, does this seem right DeadPhish Jeep CJ Forum 4 03-15-2009 09:07 PM
Rough Country Lifts NWA_CJ7 Jeep CJ Forum 8 07-26-2007 03:17 PM
