Rotor and hub? - JeepForum.com
post #1 of 8 Old 07-22-2007, 03:10 PM Thread Starter
CaliCJ5
1979 CJ5
Rotor and hub?
1979 Cj-5, Dana 30 with disc brakes. Are rotor and hub 2 separate peices because I'm trying to replace the rotor and I'm not sure if they're just rusted together.
CaliCJ5 is offline
post #2 of 8 Old 07-22-2007, 03:54 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Yes, separate.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 8 Old 07-22-2007, 04:03 PM
nozzleram
nozzleram's Avatar
To separate the rotor and hub put the lug nut on the lugs to protect the threads and pound the lugs out the back of the rotor. Some hubs will be easy to knock loose and others will have fused to the rotor due to rust and require some additional energy to remove.
77 CJ 7 - 304, TH400, Dana 300, Locked Scout 44s F/R, 4140 Chromoly Shafts, Bead locked TSL Q78s
nozzleram is offline
post #4 of 8 Old 07-22-2007, 04:06 PM
79cj7reny
1979 CJ7
FWIW, you can get the rotor/hub as an assembled unit ( not with bearings though) from the parts store. It's worth the extra coin IMO
79cj7reny is offline
post #5 of 8 Old 07-22-2007, 04:59 PM Thread Starter
CaliCJ5
1979 CJ5
Thx. Just didn't want to start banging on it without knowing. Also, do the hub bolts thread into anything other than the lug nut? Or do they just sit in the rotor and hub and thread onto the lug nut.
CaliCJ5 is offline
post #6 of 8 Old 07-22-2007, 05:58 PM
79cj7reny
1979 CJ7
Not sure what you mean, but I'll give it a shot. The bolts that hold the locking hub assembly just thread into the hub. The wheel studs are a press fit through the back of the rotor.
post #7 of 8 Old 07-22-2007, 06:35 PM Thread Starter
CaliCJ5
1979 CJ5
Ok. That makes sense to me. Can I put the bolts through the pack of the rotor and use the lug nuts to tighten the hub to the rotor before install?
CaliCJ5 is offline
post #8 of 8 Old 07-22-2007, 10:21 PM
supraman1990
supraman1990's Avatar
1980 CJ5
Yep, thats how I did it.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
75 cj5 304 rotor and distributor donkey77 Jeep CJ Forum 3 05-27-2009 07:32 PM
MSD rotor for HEI Andy5150 Jeep CJ Forum 0 03-19-2009 05:32 PM
Removing rotor collinpyle Jeep CJ Forum 12 08-15-2006 11:27 PM
Cant Get Rotor Off!! imtheant Jeep CJ Forum 2 05-13-2006 12:15 PM
rotor issues... 78_levi_cj5 Jeep CJ Forum 1 03-19-2006 01:34 PM
