Rot Under Roll Bar Repair? - Page 3 - JeepForum.com
post #31 of 65 Old 12-15-2011, 09:26 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Addicted,
Considering the roll bar is only connected to 2 thin pieces of 16 ga. sheet metal, I'm not real confident of the factory design, either. I doubt a couple of large diameter stainless washers would compromise safety too much.
I could be wrong.
Matt
Matt1981CJ7 is offline
post #32 of 65 Old 12-15-2011, 11:31 AM Thread Starter
Matt1981CJ7
1981 CJ7
Here's what I came up with for the brace under the roll bar.
As you can see, the U-channeled brace is open to collect mud and road grime from the tires. This crud ends up right underneath the roll bar. So, not only does this area collect crap from the inside, it gets a double whammy of crap from the outside, as well. No wonder it rots!!
So, I fab'd a simple end-cap for the brace. I extended the sheet metal of the end-cap all the way under the mounting bolts of the roll bar. Now, the grime can't collect in the brace, and I have an extra layer of metal to support the roll bar.
I just have to re-drill the mounting holes thru my patch, and I can move to other side. Yay!
Matt
post #33 of 65 Old 12-15-2011, 11:39 AM
addicted2dunes
1981 CJ8
Originally Posted by Matt1881CJ7 View Post
Addicted,
I could be wrong.
Matt
One big flat foot disperses the weight of an impact a lot more then four small points, it's all about surface area.
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #34 of 65 Old 12-15-2011, 11:59 AM Thread Starter
Matt1981CJ7
1981 CJ7
I understand the principle. But, since the flush-mounted design causes the sheet-metal to rot under the roll bar, the strength of the mount inherently gets compromised anyway.
I think I would rather have a rot-free connection, that may be slightly weaker, than a rotten connection, again, later on.
Just my opinion.
Matt
post #35 of 65 Old 12-18-2011, 09:20 AM
njrob
I have a question about the welding. I have the same rot and I want to tackle this repair. ( you have convinced me I can do it) Great pictures showing the tacked in repair piece . Then you jump ahead to nicely ground finished repair. What happens in between? Do you just filling between the spot welds with more spot weld until it is completely welded in place and then grind smooth?
85 CJ7, stock 258,
njrob is offline
post #36 of 65 Old 12-18-2011, 09:56 AM
addicted2dunes
1981 CJ8
Yes, you weld the panel completely in. You want to jump back and forth all around the edges doing small weld tacks as to not overheat the sheetmetal and warp it. When it's all welded in I like to take a flap disc to do the grinding because it's quick at removing the weld but doesn't dig into the surrounding metal as bad as a regular disc, it also doesn't build up a lot of heat.
Cameron Gunlock
1981 CJ8 -
post #37 of 65 Old 12-18-2011, 11:25 AM
mopar346
Dunes, If you would post a picture of what you call a flap disc, I believe I know but I would like to verify. I believe you are referring to a flexable disc on an air grinder used in body work. Am I correct?
Thanks.
Careful your character's showing
mopar346 is offline
post #38 of 65 Old 12-18-2011, 11:27 AM
addicted2dunes
1981 CJ8
Flap disc:
Cameron Gunlock
1981 CJ8 -
post #39 of 65 Old 12-18-2011, 11:39 AM
mopar346
Got it, thanks
mopar346 is offline
post #40 of 65 Old 12-19-2011, 07:10 AM Thread Starter
Matt1981CJ7
1981 CJ7
Yep, that's pretty much it. I grind the spot welds down periodically as I'm welding because it helps me to see the unfilled spots better.
I use a cutoff disc in the my grinder to remove the majority of material, then switch to an 80 grit flap disc to grind it flush. The cutoff disc is a lot faster and it doesn't heat the patch as much as the flap disc.
Here is a series of pics on a patch I did near the Jeep logo.
Good luck!
Matt
post #41 of 65 Old 12-19-2011, 07:23 AM Thread Starter
Matt1981CJ7
1981 CJ7
And here's the front panel:
post #42 of 65 Old 12-19-2011, 08:38 AM
njrob
easy welding
You guys make it look easy Thanks
85 CJ7, stock 258,
njrob is offline
post #43 of 65 Old 12-19-2011, 03:17 PM Thread Starter
Matt1981CJ7
1981 CJ7
It's really not that difficult. I first researched and watched several how-to videos, then I bought my welder 2 weeks ago. I practiced with it for about a day, then started cutting holes in my CJ. The above patch was my very first welding attempt ever, aside from practice.
Cutting and fitting the patch pieces tightly is the biggest challenge for me. I'm using a combination of a sawsall and my grinder to make the cuts. I know there are better tools for the job, but that's all I have.
Just jump in and go for it. Trust me, I had a puckered you-know-what on the first couple of cuts I made to my CJ, but now I actually look forward to getting all the cancer removed and replaced with nice clean steel.
Matt
post #44 of 65 Old 12-19-2011, 03:27 PM
wlawyer
I am pretty happy how mine turned out, I did it all myself so that was the big thing for me. Here is the finished product after the monstaliner.
This is what I started with after cutting out the rot, if I can do it I am pretty sure anyone can. Good luck.
"Man is the only creature who refuses to be what he is."
Albert Camus
wlawyer is offline
post #45 of 65 Old 12-19-2011, 03:37 PM Thread Starter
Matt1981CJ7
1981 CJ7
wlawyer,
Nice work!!
Did you paint your patch before the bed-liner? Also, how have you liked the Monstaliner? It seems to have a lot smoother texture than some of the others.
Matt
Repair old tub or get a YJ tub? rustymudder Jeep CJ Forum 1 03-11-2010 05:08 PM
What is the strongest clear coat you can roll on the roll bar over fresh paint? HHICJ7 Jeep CJ Forum 2 12-10-2009 04:27 PM
CJ Repair in NJ lbijeep Jeep CJ Forum 9 06-17-2009 08:29 AM
How would you repair this? crawdad Jeep CJ Forum 10 04-28-2008 07:30 PM
CJ5 tub repair HELP!!! imaldini Jeep CJ Forum 4 05-01-2007 05:45 PM
