Rot Under Roll Bar Repair? - JeepForum.com
post #1 of 65 Old 12-14-2011, 07:03 AM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Morning Gentlemen,
I'm going to attempt this repair, today.
I can either weld a panel back in the exact crappy design that AMC used, or I can come up with a better solution that won't rot again in the future.
Have any of you done this repair, and would you mind sharing your solutions?
Thanks
Matt
Matt1981CJ7 is offline
post #2 of 65 Old 12-14-2011, 08:26 AM
addicted2dunes
1981 CJ8
Yeah, you weld a patch in...... then paint it good..... then keep it dryer then the previous owners, will last you forever.
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #3 of 65 Old 12-14-2011, 09:08 AM
SirCrisp
Hey that's what mine looks like! I need to get a welder
SirCrisp is offline
post #4 of 65 Old 12-14-2011, 09:15 AM
mopar346
Kinda
http://www.jeepforum.com/forum/f8/gr...-weld-1292922/
Careful your character's showing
mopar346 is offline
post #5 of 65 Old 12-14-2011, 09:29 AM Thread Starter
Matt1981CJ7
1981 CJ7
LOL! My Dad and I are the only previous owners. He kept it cleaner than I do.
The problem with this area is the roll bar doesn't fit tight to the sheet all the way around the mounting plates. So, there's large gaps that accumulate dirt and moisture, with no real way to keep it clean and dry.
Another contributing factor is AMC chose to install the roll bar before they primed and painted the tub. As you can see, there was bare sheet metal under my roll bar. Bad choice.
Add to all of that the fact that the channeled brace, under the floor panel is open at the end, in the wheel well, and it collects whatever crap the tires want to deposit in there.
I think I've come up with a solution. It won't be perfect, but it should work better than the original design. I'll post some shots of the progress later this evening.
Matt
post #6 of 65 Old 12-14-2011, 09:36 AM Thread Starter
Matt1981CJ7
1981 CJ7
Mopar,
Thanks. Your repair looks good! It appears the solution is a butt-load of welding wire.
I'm gonna put a little different wrinkle on it, but basically the same.
Matt
post #7 of 65 Old 12-14-2011, 10:42 AM
mopar346
With me it's a lot of wire, but not so much with someone who knows how to handle a welder. Seam sealer is a wonderful thing and of course bedliner over the top hides a bunch.
mopar346 is offline
post #8 of 65 Old 12-14-2011, 07:27 PM Thread Starter
Matt1981CJ7
1981 CJ7
I didn't get as far as I hoped, but I made progress.
I decided to cut up the vertical side about 1.5", then make the patch in one piece. This created a seamless corner, instead of the grime collecting seam of the factory build. I'm pretty sure this will be less prone to rot.
I have an additional idea for the open end of the channel brace, underneath...in the morning.
Matt
post #9 of 65 Old 12-14-2011, 07:59 PM
mopar346
Nice.
mopar346 is offline
post #10 of 65 Old 12-14-2011, 08:41 PM
ymurf
1979 CJ7
I welded a patch in then a good coat of seam sealer then good primer and paint.
ymurf is offline
post #11 of 65 Old 12-14-2011, 08:49 PM
mopar346
I will typically treat the metal to allow the chemical it seap into every crack, the prime and seam seal the primer. Sealer and then priming might have the same effect as you piinted out earlier about the bar before the paint. Not being critical, just thought I would mention it so you could consider it before you paint.
Another thing that I have done when welding a flat piece to a ribbed piece is to cut the repalcement piece with tabs at the rib locations. This allows for a piece to fold down into the rib and be welded for a good seal.
By the way your welds look a WHOLE lot better than mine, great job.
mopar346 is offline
post #12 of 65 Old 12-14-2011, 09:03 PM Thread Starter
Matt1981CJ7
1981 CJ7
mopar,
Thanks for the encouragement. I chased a few holes around in my weld, but eventually filled everything.
By "treat the metal", are you talking a rust inhibitor of some sort?
Good tips on the tabs, and the primer/sealer/paint sequence.
Matt
post #13 of 65 Old 12-14-2011, 09:20 PM
mvigo
mvigo's Avatar
Matt,
Once you prime and paint inside you can always Linex the inside of the tub...sure helps in mine...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #14 of 65 Old 12-14-2011, 09:22 PM
mopar346
I use chemically treat the metal cause I cant spell Ozphos, Osophate, OZphosphoruos, I mean Metal Prep. You get the idea, Home Depot has it for about $15 a gallon and it is the same stuff as the $30 a guart stuff. Most say to wash it off with water after a few hours, but I prefer to lightly sand blast it, just cant take the thought of water on bare metal.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
mopar346 is offline
post #15 of 65 Old 12-14-2011, 09:28 PM Thread Starter
Matt1981CJ7
1981 CJ7
mvigo,
I'm considering that. My problem with most bed-liners, however, is the rough texture. Not only is it like sand paper on the skin, but it seems to collect more dirt than a smooth painted surface.
Can you vary the texture with Linex, or some of the other products?
Matt
Repair old tub or get a YJ tub? rustymudder Jeep CJ Forum 1 03-11-2010 05:08 PM
What is the strongest clear coat you can roll on the roll bar over fresh paint? HHICJ7 Jeep CJ Forum 2 12-10-2009 04:27 PM
CJ Repair in NJ lbijeep Jeep CJ Forum 9 06-17-2009 08:29 AM
How would you repair this? crawdad Jeep CJ Forum 10 04-28-2008 07:30 PM
CJ5 tub repair HELP!!! imaldini Jeep CJ Forum 4 05-01-2007 05:45 PM
