Rookie question........ - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rookie question........
Rough Country Lift Kits and Parts!The ULTIMATE "Selectable" Locker System! BroughIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-27-2014, 03:30 PM   #1
rdiaz
Junior Member
rdiaz's Avatar
1978 CJ5
So partsmike has graciously provided me with new balljoints(at my expense, of course) for my dana 44 knuckle assembly. Is it not a good idea to apply a small amount if grease to the outer portion of ball joint that mates with the knuckle? And a dab on the wall of the knuckle that holds the joint? Seems like it will make install slightly easier. I'm just not sure.... Thanks for the help guys.
Roy
rdiaz is offline   Reply With Quote
Unread 07-27-2014, 06:05 PM   #2
CSP
No need for grease on either of those areas. They are a press fit in both instances and you don't want something non-compressible like grease interfering with the fit of them.
CSP is offline   Reply With Quote
Unread 07-27-2014, 09:32 PM   #3
rdiaz
Junior Member
rdiaz's Avatar
1978 CJ5
Thanks CSP! I'm glad I didn't fully install the first one cause I had applied grease and then started thinking about it. I stopped after a couple millimeters and removed it and cleaned it with brake cleaner to remove all the grease. Got all 4 in tonight. Not really as tough as I thought it would be.
