Roller Rockers 304 V-8 - JeepForum.com
post #1 of 3 Old 09-25-2011, 08:54 PM Thread Starter
refderek
I purchased a set of Comp Cams 1.6 Roller Rockers with 7/16" Poly Locks. These are the only Roller Rockers I have been able to find for an AMC. My 1978 CJ-7 with Stock Heads don't even have studs. Each set of stock rockers are joined with a bridge/connector with what seems to be 1 5/16" bolts used with each rocker to bolt it to the head.
How can these work without some sort of bushing to make up the difference between the 5/16" and 7/16" in order to bolt the rockers on? Is there a better set out there which will just bolt on - the guys at JEGs never seem to have much experience with AMCs.
refderek is offline
post #2 of 3 Old 09-25-2011, 11:01 PM
mvbrady
http://www.summitracing.com/parts/CRN-52655-16/
this might be the ticket your lookin for.
mvbrady is offline
post #3 of 3 Old 09-26-2011, 05:38 AM
fuzz401
1978 CJ7
http://harlandsharp.com/amc_jeep_olds.htm
send the rockers back the only way they will work is pulling the heads off and having them machined to fit
harland makes a direct replacment rocker and why rollers unless your motor is a lot more then stock you do not need rollers
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Crane cam 1.6 roller rockers chadco Jeep CJ Forum 2 01-12-2011 07:17 AM
Roller Rockers in a 304 gatorhardy Jeep CJ Forum 10 10-15-2009 12:33 PM
360 amc roller rockers SparkyCJ7 Jeep CJ Forum 8 07-23-2009 01:54 PM
Harland Sharp Roller Rockers for a 258 Lawless_Jeep Jeep CJ Forum 0 09-19-2008 07:58 PM
newbie here.. roller rockers jeepstermike Jeep CJ Forum 6 08-18-2005 10:57 PM
