Roll Cages? - JeepForum.com
 5Likes
post #1 of 45 Old 05-16-2006, 10:52 PM Thread Starter
BigYellaJeep
BigYellaJeep's Avatar
Roll Cages?
Let's try this again.
I would like to upgrade or replace my stock/original '86 CJ-7 roll cage.
1) I would like to get one that is reasonably easy to install/bolt on.
2) I would also like one that bolts to the frame, and not that flimsy tub.
3) Relatively cheap or budget friendly.
4) Don't REALLY need a full cage per se, but for the people in the front two seats..
Any suggestions/pics/negotiations?
TIA
Current Corvette: '01 Z06
Last Jeep: 98 Sport TJ
1st Jeep: '86 CJ-7 (I miss her)
BigYellaJeep is offline
post #2 of 45 Old 05-17-2006, 12:00 PM
jeepskate
You're not going to find what you're looking for with that wish list. The bolt in ones aren't cheap and don't tie to the frame. The cheap ones aren't bolt in and don't tie to the frame. Nothing ties to the frame and is bolt on.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 45 Old 05-17-2006, 12:14 PM
MeCasa
Especially in chrome
Hehe, couldn't help myself ;-)
Sex is dirty only if it's done right .... Live and Let Live .... Rules are Boring and I Don't Like Them
................................................ MeCasaEsSuCasa .................................
MeCasa is offline
post #4 of 45 Old 05-17-2006, 01:22 PM Thread Starter
BigYellaJeep
Ohhh, you dog..lol.
I want a roll cage that won't poke through the dang tub when the Jeep rolls, you know? So I guess I need to build my own?
Oh, and I said relatively cheap, not $10 cheap.
I can always wrap tin-foil around it anyway.
post #5 of 45 Old 05-17-2006, 01:25 PM
Brandon11130
just make sure you wrap the tin foil cage in foam so you dont smash your head on it when you roll, trust me it hurts
1959 JEEP CJ5
We do not ask for your poor or your hungry. We do not want your tired and sick. It is your corrupt we claim. It is your evil that will be saught by us. With every breath we shall hunt them down. Each day we will spill their blood ‘til it rains down from the skies.
Brandon11130 is offline
post #6 of 45 Old 05-17-2006, 01:42 PM
Trigger
Try Poison Spyder Customs. They've got a kit for a CJ that runs right around $700. All you need to do is have someone weld it together for you. One thing I can say about cages is don't go cheap. I've personally seen a roll cage save my friends' lives and when I get to putting one in my Jeep, it's going to be a good one.
Trigger is offline
post #7 of 45 Old 05-17-2006, 02:44 PM
jeepskate
Relative means that you have something to compare it to, so define relatively cheap for you. For example, an H2 is relatively cheap compared to an H1, but it's still a large chunk of change to me but not to Shaq.
You don't have to go custom, but that would get you *exactly* what you want with a price tag to match. The frame tie-ins will at least be semi-custom. Their are kits and components out there, but you have to cut & weld to fit your situation.
post #8 of 45 Old 05-17-2006, 07:19 PM
TheJunkMan2005
Want an inexpensive rollbar.. Find a local guy with a big 4x4 truck that works on race cars. Chances are he'd happily help you out, nothing a 30pack can't handle, of course for after the job is done... I already have 3 people volunteering to modify my dune buggy, and do my rollbar in my CJ, met all the people the same way. Just see a race car, and talk to them..
Len
1988 Wrangler 89000 miles, no rust, no rot, all nice and pretty.. Runs down the highway really nice too.. This is great fun.
TheJunkMan2005 is offline
post #9 of 45 Old 05-17-2006, 08:30 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A couple buddies of mine ordered kits and add-ons from SW Racecars... pretty good price delivered right to the front door. Of course, we had to weld the kits in and then fab up our own frame tie ins but it was relatively inexpensive and easy to do. If you decide on one of their kits, make sure to specify 1.75"x.120" DOM. They actually offer a couple different sizes of tube..
BESRK is offline
post #10 of 45 Old 05-18-2006, 07:40 AM Thread Starter
BigYellaJeep
Yep, I think that I'm gonna go find a guy who makes his own cages like you all suggested. Now I just need to FIND "that guy."
Relatively cheap was in terms of roll cage average cost... so if they range from the $300-1,000 mark, then something around $400, etc.
post #11 of 45 Old 05-18-2006, 10:02 AM
jeepskate
You should shop by what sort of protection you need, not necessarily by price. The amount and type of tubing and number of bends (labor) affects the price. A $300 cage will be just the basics...front hoop, 4 spreaders, dash bar is typically what you get in the $300-400 range. So the question is, is that adequate to save your bacon in the types of situations you put yourself in? A $1k cage will be gussetted & triangulated, have seat & harness mounts, etc. Obviously with a little planning, you can start with the $300-400 cage and add gussets and additional tubing as you go, but I wouldn't expect to have it tied to the frame in that intial outlay...probably need to add another $100 or so for that.
post #12 of 45 Old 05-18-2006, 11:45 AM
Sprkplug
1978 CJ7
X2
Got my front from S&W. Rear section is from a 94 YJ and I added some tubing to it as well.
Next will tie in the seats and frame and install 4-point harness (after adding another section of tubing behind the front seats).
Sparkplug
1978 Jeep CJ 7 258 6cyl Quadra-Trac with T400. Custom 3" body lift. Flatfendered. Custom bumpers. Full 6 point roll cage. 36" IROK's. 2 1/2 suspenion lift and 1/2 shackle lift. GM HEI, Superior 1-piece axles, 4.88 gears, Weber carb. Locked front and rear. Best of all, fours sons who LOVE TO RIDE!
Sprkplug is offline
post #13 of 45 Old 05-18-2006, 02:41 PM Thread Starter
BigYellaJeep
That's nice Sprkplug. Definately something like that I'm looking for... is it mounted to the frame/chassis or to the tub?
post #14 of 45 Old 05-18-2006, 02:42 PM
barry1me
barry1me's Avatar
I just called SW for some quotes for roll cages $169.99 for a cj7 8 point mild steel
Problem is I need one for a CJ5...the salesman wasnt all that knowledgeable on there products, and said they didnt make one for a 5. He said I would have to fill out a special request form for a 8 point which starts at $259.99 mild steel, and $429.99 for DOM. I dont understand why I should have to pay nearly $100 more for my cj5 which uses less material? Does anyone have any type of connection there that might be able to help me out?
barry1me is offline
post #15 of 45 Old 05-18-2006, 03:43 PM
jeepskate
Depending upon how it's made, might be a simple matter of just cutting the front spreaders shorter to fit your '5. They charge more because they have to take the time to get the specs and model the cage...it's not cookie cutter like the ones they already have done the legwork on. All manufacturers charge more for custom orders whether it's a roll cage or a decal.
roll cages KRIZB Jeep CJ Forum 2 09-10-2008 06:18 PM
Roll Cages tank06 Jeep CJ Forum 0 08-05-2008 06:09 PM
Roll Cages? 79 CJ7 Jeep CJ Forum 5 04-02-2007 04:37 AM
roll cages MudMonster Jeep CJ Forum 2 02-09-2003 07:37 PM
Roll Cages YJproject90 Jeep CJ Forum 0 11-25-2002 05:56 AM
