#1 | |
Roll Bar Padding
80 CJ7 I am a little newer to this, and need a roll bar pad for my jeep. Most of the ones i have seen the roll bar has the the 2 front bars that go up and mount to the window frame. Mine actually goes up to the window frame then down and mounts to the floor on the driver & passenger side. Anyone know what I am talking about? And where I can find a pad? Thanks,
#2 |
Sounds like you have a full cage. Check with Bestop, they may be able to custom make something for you, or maybe Rugged Ridge. Or you could get some roll bar padding from Summit or Jeg's and have covers made to match your interior color.
#3 |
i think O.R. fab sells a padding kit for that setup
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad. |
#4 |
aka Mike
Go to a plumbing supply house and get some pipe insulation. It's call Rubitex (Sp?). It what we use to insulate pipes in buildings. It is available in tons of ID and OD combinations and is usually sold by the foot. then you can use a hole saw or just about anything to make you corners and junctions.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 33x10.5x15 BGF TA KO on Crome Modular rims. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX. Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love. http://main.nationalmssociety.org/site/TR/Walk/VABWalkEvents?px=6419856&pg=personal&fr_id=18331 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
