#1 | |
Roll Bar Padding??
Where do you guys buy your roll bar padding? I purchased some from a 4wd drive part shop 30 miles from my house only to get home and find that the diameter was way too small......I figured all cages were the same diameter....shame on me.
Is there a place that sells different sizes? Is there an "average" size for aftermarket cages- I've got one, but don't know the name/type. Thanks for any help- -Busa196-
81 CJ7 Renegade, T-176, Chevy 305, Extreme 4x4 Comp Cam, Hedman Headers, no cats, dual 40 series Flowmasters, Power Brake Conversion, Rhino Lined, 4" suspension lift, 315/75/16's on 16x10 Mickey Thompson Classic II's, Original paint & Tub. '08 JK, Auto, Hesco Supercharger, 6psi, Unichip, Borla Cat Back, H.I.D. head/fog lamps, 33's. |
#2 |
Are you sure it's too small? It's a very snug fit. It has to be so they don't look all wrinkled when they're installed.
#3 |
Yeah, it's not even close. It looks like I'd have to cut out 1/4 of another one in order to cover the entire bar?
#4 |
I used the foam race car rollbar stuff with zip ties....works like a charm.
----------------------- I used to own a CJ....:-( http://www.bustedjeep.com AIM: Qsting68 |
#5 |
Jegs and Summit both carry the padding.
AMC 401, Howell TBI, NP-435, Atlas 4.3, Rockcrusher 60, Shaved 14 bolt, 110" WB, Stazworks Double Beadlocks and 42's... |
#6 |
Junior Member
Anybody know the diameter of a stock CJ roll bar off hand? At work, can't get to the Jeep to check myself. Thanks!
#7 |
At the sand dunes a guy was selling the noodles kids use in the swimming pool. He said they fit fine. I don't know I didn't see any being used. It might be a thought.
#8 |
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Corvette Master Cylinder | HAD Shafts | 35 Toyo MT's| If you own a Jeep and serve in or are a Veteran of the U.S. Military come visit us at: MilitaryJeepers.com
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
