Rocker panel trim - Page 2 - JeepForum.com
post #16 of 24 Old 02-24-2013, 07:23 PM Thread Starter
Retta9
Yea I've seen several that the trim covers the hole and others where it actually goes around and leaves the hole exposed. Some may even actually have been filled or patched. The lower part of my rocker panels have a wavy look to them and I just want some different options to try and hide the imperfections. The trim on it now is just a hair to short, I need somethin to sit slightly higher but cover all the holes. If I can't have both I'd rather have somethin sit a little higher. Any suggestions?
Retta9 is offline
post #17 of 24 Old 02-25-2013, 01:32 PM
RamblingCJ
Originally Posted by keith460
There's no variation for the amount of holes from 1976-86 CJ-7's All had five holes per side, four in the tub and one on the front fender. CJ-5's had four holes per side I believe but not sure.
I have 5 holes per side, but no hole on the fender. I have two directly after where the tub and fender meet and this is factory.
Not the best of pictures, but no hole in fender here.
RamblingCJ is offline
post #18 of 24 Old 02-25-2013, 05:39 PM
keith460
Jeep. There's Only One
keith460's Avatar
Typical AMC/Jeep. They probably did that after changing the Jeep stamping on the sides from Jeep to Joop Mid 1984
1984 CJ-7 Renegade
keith460 is offline
post #19 of 24 Old 02-25-2013, 10:58 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
My '85 had the holes in the original OEM fenders and Joop on the tub.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #20 of 24 Old 02-25-2013, 11:42 PM
RamblingCJ
I guess they did a quick change for the 86 then. Or maybe this has to do with the Laredo package itself. This is kinda odd, as most CJ year comparisons are.
Edit: Well, I guess you're a Laredo too. Just straight weird.
post #21 of 24 Old 02-26-2013, 03:28 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
No Holes on my base V8 '79 CJ7. Then again I have no rocker trim whatsoever. Not even the protrusions on the fenders. FWIW
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #22 of 24 Old 02-26-2013, 06:31 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My all original '81 tub has the holes.
I'm guessing the fenders that don't have the holes have been replaced at some point. But I could be wrong....
Matt
Matt1981CJ7 is offline
post #23 of 24 Old 02-27-2013, 07:37 AM
hutch1200
hutch1200's Avatar
1979 CJ7
Matt
Mine were factory fenders. I've known the CJ since new, and bought it from a family friend in '83. But Pre '81s were a little more plain than their later siblings.
post #24 of 24 Old 02-27-2013, 11:13 AM
RamblingCJ
Yeah, I'm the second owner and I'm pretty sure the fenders are original.
