Rocker Guards and Bondo - JeepForum.com
post #1 of 8 Old 06-17-2010, 03:49 AM Thread Starter
putty31
All,
I just had a question, and I can post some pics later, about how to cover up the unsightly large amount of bondo on the drivers side rocker area. I want to get one of those diamond plated rocker guards with the lip, but my concern is if I'll be able to rivet in place with the amount of bondo that is on there. First, does anyone know if bondo is strong enough to rivet and second, if it isn't does anyone have a better idea to make the CJ more presentable? I'll get some pictures later today and post them, so you can see how much bondo was put on this area.....
putty31 is offline
post #2 of 8 Old 06-17-2010, 04:03 AM
dtcohen
1980 CJ7
Is the bondo filling up rust holes or just smoothing out dents? If there is solid metal behind the bondo then you might get away with bolting the rocker guards on. I have a feeling that the bondo is filling up rust holes, and if that is the case then your best bet is to get all that bondo out and weld in some patch panels.
dtcohen is offline
post #3 of 8 Old 06-17-2010, 03:00 PM
Bubba Ray
Check out the rock sliders from Shrockworks. Nice and well built and cover a lot of sins. Not cheap.
Bubba Ray is offline
post #4 of 8 Old 06-17-2010, 03:10 PM
slowman9786
1981 CJ7
You can't rivet bondo. Just trying to drill for the rivets will probably crack it.
I guess it depends on how thick it is. You might want to grind some away to see if its rust or a dent. If its a dent, you can just hammer it out and then rivet to it.
slowman9786 is offline
post #5 of 8 Old 06-17-2010, 03:40 PM
crzdmnky
1978 CJ5
If its on you rocker panels, i would say just take a piece of metal and screw it to the back side of the panel, and grind off the screws, then place your rocker panels up on your jeep, and make sure to penetrate to the sheet of metal you placed on the other side. They should hold. Hope this helps.
crzdmnky is offline
post #6 of 8 Old 06-18-2010, 01:35 AM Thread Starter
putty31
That sounds like a great idea....I think thats what I'm going to have to try. I could care less what it looks like underneath there. Thanks a lot!
putty31 is offline
post #7 of 8 Old 06-18-2010, 02:36 PM
crzdmnky
1978 CJ5
Yup, this is what I did, I just form fitted metal on the back side to give the bondo something to hold on to and smoothed it all out. Havent put rocker panels on yet, I have the metal just havent cut it to fit yet.
crzdmnky is offline
post #8 of 8 Old 10-21-2011, 04:25 AM
mashunitjeep
1991 XJ Cherokee
one bi gpoint th kill the rust first there is a spray that kills it then it turns to primer hate to have u bondo only to have the hole get bigger from the moisture
Im not related to kate middleton
mashunitjeep is offline
cj5 rocker guards.. blackhawk51 Jeep CJ Forum 10 06-01-2010 09:52 PM
Will YJ rocker guards fit a CJ? jatepper Jeep CJ Forum 3 07-05-2009 07:07 PM
Kentrol Rocker guards Big Tool Jeep CJ Forum 1 04-14-2007 08:55 PM
rocker guards? Jermy01 Jeep CJ Forum 6 07-22-2005 02:46 PM
Rocker guards? rok_toy Jeep CJ Forum 2 06-15-2003 12:21 PM
