Rocker bridge issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Rocker bridge issue
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRugged Ridge Deals at JeepHut.comRough Country Lift Kits and Parts!
Unread 01-19-2015, 09:42 AM   #1
Budowski
Budowski's Avatar
1978 CJ7
Rocker bridge issue
I am rebuilding my 78 258 and snapped a bridge when installing. Mine are the one piece bridges. I ordered a new bridge from Omix ADA (the website pictured the one piece that I have)and what arrived is the 3 piece. Omix ADA is still trying to figure things out so:
1. Will this bridge work for my motor?
2. Is it ok to mix and match the 1 piece and 3 piece bridges? Or should I get a whole set of the 3 piece bridges?
Thanks!
'78 Rebuilt 4.2 258, T150, Spicer 20, Dana 30 front, AMC 20 rear
'80 CJ7 frame
Corrected: '84 CJ Tub
Budowski is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:04 AM   #2
slomo19er
1983 CJ7
I can see the one piece being possibly stronger. Either "should be" fine in a low rpm Jeep engine.
slomo
slomo19er is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:12 AM   #3
gmakra
Its really a non issue you will be fine.
gmakra is offline   Reply With Quote Quick reply to this message
