Rocker Arm Torque Specifications - JeepForum.com
post #1 of 5 Old 10-06-2003, 09:01 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Question Rocker Arm Torque Specifications
I have an urgent question!!!
I have a 4 cylender 2.5L stock engine on my CJ7.
I need to know how many lbs of torque is specified for the Rocker Arms to be tightend to.
Thank you!
Aphelion79 is offline
post #2 of 5 Old 10-06-2003, 10:04 PM
Lightningdon
Lightningdon's Avatar
I show 19ft lbs in the inline 4-150. And 20 ft lbs in the 151. I'm not sure which engine is the 2.5 L. My manual only lists as the 150cid and 151cid. Anyhow you're safe at 19 ft lbs.
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #3 of 5 Old 10-07-2003, 07:46 AM Thread Starter
Aphelion79
Aphelion79's Avatar
All right, thanks! Just for my info: could you tell me what manual you're using? Im looking to get a good repair manual, so far choices between Haynes and Chillton (i cant spell, btw...)
post #4 of 5 Old 10-07-2003, 01:43 PM
Lightningdon
I actually have both Chilton and Haynes manuals. One manual is better on certain things, while the other is better at other stuff. I get a lot of use out of both. A factory service manual would be a very good thing to have.
'97 TJ
post #5 of 5 Old 10-07-2003, 01:49 PM
aviator
aviator's Avatar
I agree completley... get them both!! I've got the facotry manual too, but it doesn't have anything in it that the Haynes or Chiltons doesn't have.
Ricers make great Jack stands! Give 'em a try!
aviator is offline
Torque Specs For rocker Arms ? Oily Jeep CJ Forum 3 07-19-2009 10:51 AM
Rocker Arm Bridge Torque Specs? tlhigh Jeep CJ Forum 0 04-29-2009 09:55 PM
torque specifications - front axle D30 certifiablejeep Jeep CJ Forum 1 03-12-2007 07:06 AM
258 Rocker Arm Bolt Torque 7DJEEP Jeep CJ Forum 5 01-15-2007 02:50 PM
'76 Cj5 Specifications redcj576 Jeep CJ Forum 1 10-02-2001 10:08 PM
