RockCrowling susp. for CJ7? - JeepForum.com
post #1 of 11 Old 10-08-2003, 09:25 AM Thread Starter
Muttley
Muttley's Avatar
Talking RockCrowling susp. for CJ7?
Need any help to decide if I change my 1986 CJ7 for a SOA suspension ou for a BLACK DIAMOND XCL (coil-over)suspension.
Note that I ALSO use it on road / highway...
Now I have SUA with RANCHO 2-1/2", front shackle inversion kit, 3" body lift and Goodyears MTR 35".
Also ARB Air lockers front & rear, Warn M12000 winch, Warn full floating rear axle (on AMC20) and WARN heavy duty front axles & hubs on stock Dana 30.
Engine is a 5.7 V8 FI, GM4L60E transmission & Dana 300 with Lomax 4:1...
Muttley is offline
post #2 of 11 Old 10-08-2003, 10:19 AM
Brock
Brock's Avatar
Take the body lift off and do a SOA and upgrade steering. The XCL is cool but very expensive and the soa will flex just as well.
Brock is offline
post #3 of 11 Old 10-08-2003, 10:41 AM Thread Starter
Muttley
Muttley's Avatar
Hi!
Thankx for your opnion... but let me ask you a few more questions: (i donīt know nothing about SOA and had hear so many different opnions until now...)
1) Do you already have a SOA on you CJ7??
2) How it "handles" at highway hi-speeds / turns?
3) Do you know if I can keep my RANCHO springs with SOA application?
4) What about the shackles inversion kit that I already have in front? May I keep it????
5) If you have a CJ7 w/ SOA, what SHOCKS you are using? Rancho RS9000 is a good option? (because we have Rancho here in Brazil...)
6) What about SPRING WRAP??
Sorry about all those questions...
Best regards
Muttley
From Brazil
Muttley is offline
post #4 of 11 Old 10-08-2003, 01:32 PM
MudLover
MudLover's Avatar
I'd say if you've got the money and the skills/ability to get the coils.... DO IT! I think that kit would be the coolest thing under a CJ. Coils flex great, and the ride should be a lot smoother. All comes down to green backs (and those new cute peach collored 20's). The only problem I have with coils is that there's so much more to break and leaf springs are easier to understand.
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #5 of 11 Old 10-08-2003, 02:16 PM
Brock
Brock's Avatar
Read this information and then do a search on the CJ board. The SOA lift requires precise measurements and welds to be safe. SOA discussion
Brock is offline
post #6 of 11 Old 10-08-2003, 10:57 PM
eight
eight's Avatar
The SOA will probably ride better than the soils on the highway. I'd ditch the body lift and any shackle lift you have. Do the SOA on the 2.5" springs. With the lift springs you shouldn't have to worry about axle wrap like you would with stock springs. Keep the shackle reversal kit you have. (It's not called shackle inversion, that's something else.) Ranchos are fine. Use the longest shocks you can fit. You'll need a CV drive shaft on a cj7 with that much lift.
eight is offline
post #7 of 11 Old 10-09-2003, 06:19 AM Thread Starter
Muttley
Muttley's Avatar
THANKX MAN!!
I will try that...
What you think about the REVOLVER SHACKLES with SOA?
Azad "Muttley" Tarikian
Sao Paulo - Brazil
.br
1986 Jeep CJ7 Renegade
Muttley is offline
post #8 of 11 Old 10-09-2003, 07:44 AM
Brock
Brock's Avatar
The soa will flex well enough. The revolver shackes are either loved or hated by people. I personally wouldn't waste the money. Maybe get some greasable bomerang (without lift) shackles if you are running the stock ones.
Brock is offline
post #9 of 11 Old 10-09-2003, 08:37 AM Thread Starter
Muttley
Muttley's Avatar
Where I can find (www?) this bomerang shackles???
Thankx!!
Sao Paulo - Brazil
.br
Muttley is offline
post #10 of 11 Old 10-09-2003, 09:02 AM
Brock
Brock's Avatar
Thankx!!
Here is a good spot. You might want to search around for the best price. M.O.R.E.
Brock is offline
post #11 of 11 Old 10-09-2003, 09:04 AM
Brock
Brock's Avatar
M.O.R.E. also has frame reinforcing plates that you were looking for in your other thread. They should fix you frame cracking problems.
Brock is offline
Body Lit or Susp. Lift? TexasCJ7 Jeep CJ Forum 6 01-14-2007 04:58 PM
susp.. question rmballou Jeep CJ Forum 2 01-03-2007 06:40 PM
XJ (cherokee) front susp. on a CJ/YJ Crash&Burn Jeep CJ Forum 8 06-28-2006 12:35 PM
4 Inch Susp. lift question markusinacj7 Jeep CJ Forum 2 03-30-2005 06:35 PM
4'' susp lift vs. 4" susp + 3" body c-dogg Jeep CJ Forum 3 01-08-2004 03:44 PM
