Rings and Bearings w/ motor in the Jeep? - JeepForum.com
post #1 of 5 Old 06-15-2008, 05:18 PM Thread Starter
243
1978 FSJ Cherokee
I found a NOS Rochester Varajet last week and really want to get my Jeep on the road while I rebuild the T176, D300 and the TBI 350 over the winter. Two of four cylinders had low compression and it's running rich so now I am wondering if I have some cracked valves.
If I pull the head to check the valves, could I also pull the pistons, drop the crank and re-ring it?
Dave's 78 Build
243 is offline
post #2 of 5 Old 06-15-2008, 06:07 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If I were gonna do that, I'd just pull the engine and put it on a stand. It's a whole lot nicer doing piston work when 10W30 isn't dripping in your eyes... Not much to pulling that little Iron Duke.
BESRK is offline
post #3 of 5 Old 06-16-2008, 06:33 AM
steveracer67
1963 CJ5
Not too mention you ever try to torque rod and main bearings upside down? Plus do clearances for bearing preload and sideload.
steveracer67 is offline
post #4 of 5 Old 06-16-2008, 06:46 AM
Curt Reinhardt
1978 CJ5
If you re-ring it you should at minimum hone the cylinders to remove glaze.
You're talking about doing the better half of a rebuild. You would save time and have a shot at doing a much better job with the engine on a stand like BESRK suggested.
Curt Reinhardt is offline
post #5 of 5 Old 06-16-2008, 07:30 AM Thread Starter
243
1978 FSJ Cherokee
Ya'll are right, it's a tiny little four-banger so pulling it's no sweat. If I do, I can replace the clutch and the front bearing in the T176 at the same time.
Before I pull it though, I am going to re-check the compression to see if 2 and 3 are the low cylinders which could be a head gasket. I think a leak-down test would make sense too...I may get lucky and find a bad valve or blown head gasket and an easy repair.
Dave's 78 Build
243 is offline
another possibility to swapping Jeep with Ford motor alisa65 Jeep CJ Forum 0 05-05-2009 05:20 PM
Paint the motor in the Jeep or leave it? danheit Jeep CJ Forum 16 03-05-2009 07:53 PM
What motor is in my Jeep? Is this the right carb?? jrb1449 Jeep CJ Forum 6 06-21-2008 07:36 AM
Why do I have tapered bearings instead of flat bearings on my axles? part.changer Jeep CJ Forum 9 08-02-2007 01:21 PM
Where do I locate I D # on 4 liter Jeep Motor Furry Jeep CJ Forum 1 04-21-2007 09:58 PM
