ring and pinion woes (REFINED) - JeepForum.com
post #1 of 21 Old 07-08-2013, 03:02 PM Thread Starter
jodowii2
1980 CJ7
okay so my in my last thread there was a lot of confusion so im going to re do this
ok my dana 30 in my 80 cj the pinion bearings went out causing then ring and pinion to eat each other alive
i got a used ring and pinion off of ebay the description said dana 30 ring and pinion 3.55 gear ratio (LONG pinion) so i ordered it
both the same length look a little different in the mid section
bought the correct bearings (same numbers as the old ones)
the inner looks like it will go on fine havent pressed it on yet
the outer tho
where the outer bearing seats is a couple thousands different that the old (bigger)
OLD
Measures 1.129
NEW
Measures 1.190
there are some numbers on both of them
OLD
NEW
i need to know what pinion i have?
i need to know what outer bearing i need?
will this pinion work?
jodowii2 is offline
post #2 of 21 Old 07-08-2013, 04:02 PM
CSP
Dana's website shows part #44226 as a pinion no longer made. Their application that shows where it was originally used turns up nothing.
It's odd that the tooth counts are not the same. They should be. Have you compared the ring gear to the existing ring gear to make sure that the diameter is the same and the crown heighth is the same? I get the feeling that you have a JK Dana 44 pinion there, not a Dana 30. The tooth counts on both sets should be the same if they are for the same axle.
CSP is offline
post #3 of 21 Old 07-08-2013, 04:07 PM Thread Starter
jodowii2
1980 CJ7
Haven't counted yet but it bolted to thw carrier for the dana 30
jodowii2 is offline
post #4 of 21 Old 07-08-2013, 05:33 PM
CSP
I already know the tooth count is different. The count is stamped right on the pinion. The original is 46-13 and the new one is 39-11. First number is the ring gear teeth and the second is the pinion.
I didn't ask if the ring gear bolted to the pinion.
CSP is offline
post #5 of 21 Old 07-08-2013, 05:35 PM Thread Starter
jodowii2
1980 CJ7
So its s dand 44 pinion?
jodowii2 is offline
post #6 of 21 Old 07-08-2013, 05:37 PM Thread Starter
jodowii2
1980 CJ7
And I'm saying it nolted to the cage that houses the spider gears (idk what the correct termonalgy is)
jodowii2 is offline
post #7 of 21 Old 07-08-2013, 06:39 PM
CSP
I understand that it bolts to the carrier. That's not the answer to the questions about the diameter and the crown height.
You couldn't ask the seller what it came out of?
CSP is offline
post #8 of 21 Old 07-08-2013, 06:45 PM Thread Starter
jodowii2
1980 CJ7
Yes I can and I will measure them sorru for the confusion
jodowii2 is offline
post #9 of 21 Old 07-08-2013, 07:50 PM Thread Starter
jodowii2
1980 CJ7
What do u mean measure the crown?
jodowii2 is offline
post #10 of 21 Old 07-08-2013, 08:50 PM
lucdog
lucdog's Avatar
1980 CJ5
I think what CSP means is lay the old and new ring gears, (aka crown gear ) on a flat surface and measure the height of both. The easiest way to do this is to lay a flat bar across the teeth, and measure from the flat surface to the bottom of the bar.
My wag is one of the ring gears is thicker, and it's the one with 39 teeth on the ring gear.
The correct term is the carrier, ie, " I bolted the ring gear to the carrier"
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #11 of 21 Old 07-08-2013, 08:55 PM Thread Starter
jodowii2
1980 CJ7
Thanks bill I'm just trying to figure this whole front end out ..... just want my jeep bavk on the trail
jodowii2 is offline
post #12 of 21 Old 07-08-2013, 09:07 PM
lucdog
lucdog's Avatar
1980 CJ5
This is what were after.
http://www.jeepforum.com/forum/f9/do...gears-1127266/
Wether or not you have the correct set, I don't know. This is why the diameter and height is important.
If it were me, I would have ordered a new set.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #13 of 21 Old 07-08-2013, 09:16 PM Thread Starter
jodowii2
1980 CJ7
I woukd have love to buy a new set but I don't rely have the funds for that
jodowii2 is offline
post #14 of 21 Old 07-08-2013, 09:36 PM
CSP
Or at least buy a new set that you know for sure came out of a CJ.
CSP is offline
post #15 of 21 Old 07-09-2013, 08:01 PM Thread Starter
jodowii2
1980 CJ7
Got some more info the crown height on the old is 1.230 and the diameter is 7, 1/8 inches
The new crown is 1.215 and the diameter is 7, 1/4 inches seems a little different
jodowii2 is offline
