ring and pinion woes - Page 2 - JeepForum.com
post #16 of 20 Old 07-08-2013, 10:37 AM Thread Starter
jodowii2
1980 CJ7
Bump need some assistance
jodowii2 is offline
post #17 of 20 Old 07-08-2013, 11:43 AM
foggybottombob
There are 4 Dana 30 axles that I am aware of.
1) The CJ/Bronco/IH Scout II long pinion std cut version
2) XJ/YJ short pinion reverse cut (high pinion)
3) TJ short pinion std cut
4) JK dana 30 (not really familiar with this)
Only #1 above was used on a CJ from the factory. All the pinion shafts for these will be exactly the same length. You say you need assistance but you don't say what you need assistance with.
XJ TJ CJ PINION Diameter @ inner bearing 1.376"
XJ CJ PINION Diameter @ outer bearing 1.125" ; 26 Spline
std cut CJ Dana 30 Pinion length 8 9/16":
CJ,XJ-95 Outer Pinion Bearing: (same D44): (Set50) Timken 02872 ; Race 02820
CJ,XJ,TJ Inner Pinion Bearing (Same Isuzu D44): Timken HM88649 ; Race Timken HM88610
foggybottombob is offline
post #18 of 20 Old 07-08-2013, 11:53 AM Thread Starter
jodowii2
1980 CJ7
Where the outer bearing seats on the pinion on my new pinion is a couple thousandths bigger to much bigger that it won't lwt the bearing be pressed on (see posts above
jodowii2 is offline
post #19 of 20 Old 07-08-2013, 12:00 PM Thread Starter
jodowii2
1980 CJ7
I need to know what bearing I need for this pinion or I'm gonnq have a machine shop turn it down to the sive of my old one
jodowii2 is offline
post #20 of 20 Old 07-08-2013, 02:25 PM
80cj
80cj's Avatar
1980 CJ5
I believe TJ D30 ring and pinions are a different length than those used on a CJ because TJ D30 R&P's use a crush tube.
80cj is offline
