ring and pinion woes - JeepForum.com
post #1 of 20 Old 06-14-2013, 08:25 AM Thread Starter
jodowii2
1980 CJ7
So the ring amd pinion wemt out on my jeep because of water in the diff case from po I ordered a used ring and pinion and such and the new pinion was about an inch shorter when they switched to wode track axels did the pinion area change and what years could I look to get a used one ?
jodowii2 is offline
post #2 of 20 Old 06-14-2013, 08:49 AM
jeepwhore
Nope, the center section of the M20 didn't change at all through the years. Sounds like someone sent you gears for the wrong axle.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 20 Old 06-14-2013, 08:55 AM Thread Starter
jodowii2
1980 CJ7
Sorry I should have specifide it is the front axel dana 30
jodowii2 is offline
post #4 of 20 Old 06-14-2013, 09:02 AM
lucdog
lucdog's Avatar
1980 CJ5
No difference there either. AFAIK.
Did you get the parts I sent, I haven't heard anything?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 20 Old 06-14-2013, 09:24 AM Thread Starter
jodowii2
1980 CJ7
Yes I did I have been busy with a bunch of stuff I will get ur money sent out monday or tuesday and the parts guy ended uo finding one from like a 90ish cherokee I think still said It was a dana 30
jodowii2 is offline
post #6 of 20 Old 06-14-2013, 09:54 AM Thread Starter
jodowii2
1980 CJ7
What about one from a 85 -95 wrangler would they be the same?
jodowii2 is offline
post #7 of 20 Old 06-14-2013, 10:44 AM
CSP
No they wouldn't. You need gears from a CJ. A YJ has reverse cut gears as do many years of XJs. The TJ has a different pinion, which is what it sounds like you got.
CSP is offline
post #8 of 20 Old 06-14-2013, 10:53 AM Thread Starter
jodowii2
1980 CJ7
Alright that's what I was thinking
jodowii2 is offline
post #9 of 20 Old 06-14-2013, 04:16 PM
SLO_Ken
What ratio are you looking for? I've got a used set of 3.31's I'd let you have cheap.
SLO_Ken is offline
post #10 of 20 Old 06-14-2013, 04:19 PM
MoC
I would get the cash first so that you not waiting for him to have time..
MoC is offline
post #11 of 20 Old 06-14-2013, 04:23 PM Thread Starter
jodowii2
1980 CJ7
Looking for 3.54s
jodowii2 is offline
post #12 of 20 Old 06-15-2013, 08:49 PM
foggybottombob
The CJ, Scout and early Bronco Dana 30's are the long pinion std cut style. Most XJ and all YJ Dana 30s are short pinion and reverse cut. The last couple of years of XJ had the short pinion std cut front Dana 30 like a TJ wrangler.
foggybottombob is offline
post #13 of 20 Old 07-06-2013, 05:01 PM Thread Starter
jodowii2
1980 CJ7
well i got a long pinion off of ebay for 85 bucka got it looks great i go to get bearings and the inner looks like it will work havent pressed it on yet but the outer on the pnion is different on my new pinion compared to my old it is bigger quite a bit bigger
old
new
what did this pinion come out of so i can get the correct bearings and get this thing running
jodowii2 is offline
post #14 of 20 Old 07-06-2013, 06:19 PM
CSP
You can't just use a used pinion to replace the one you had. Ring and pinions absolutely have to be used as a set and kept together. They are lapped together as they are manufactured and if you use one pinion in place of another it will lead to a very short life for both the ring gear and the pinion.
You need a CJ Dana 30 ring and pinion set. They can be used but they must come together.
CSP is offline
post #15 of 20 Old 07-06-2013, 06:24 PM Thread Starter
jodowii2
1980 CJ7
I have the ring tooo I was just in a hurry and didn't type it
jodowii2 is offline
