Rewiring a CJ 5 - JeepForum.com
post #1 of 7 Old 12-21-2005, 08:25 AM Thread Starter
72JEEPCJ5
Rewiring a CJ 5
I need to rewire my 72 CJ5. Where should I start? I'm having a had time with the alternator recharging the battery, so I figure I should just start over by rewiring. I'm looking for a good wiring diagram. Any and all help would be helpful. Thanks fellow Jeeper.
72JEEPCJ5 is offline
post #2 of 7 Old 12-21-2005, 08:28 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Are you on a budget or no?
If not, I say go with a good kit, makes life a lot easier.
If so, then I would say that you will need a good harness that hasn't been hacked into that badly to start with and also check the wires to see if they are corroded. If everything checks out, then you can go from there with manuals and such for wiring diagrams.
No budget, then check these out
http://www.certifiablejeep.com/wiring1.php
Wiring starts on this page and goes for a few others
http://www.certifiablejeep.com/thirdproject17.php
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #3 of 7 Old 12-21-2005, 10:01 AM
solitudetree
Wiring diagrams are also available through autozone at their website. Simply put in the type of vehicle and then follow it to electrical. Wiring diagram info is on the right hand side of the page.
All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
solitudetree is offline
post #4 of 7 Old 12-21-2005, 10:30 AM
John Strenk
John Strenk's Avatar
1976 CJ5
72 is an interesting year in that they had no fuse box. Just inline fuses all over the place.
They are pretty simple to wire and it might be worth your time to purchase a universal kit unless you like to keep it close to stock.
It's been a long time since I owned my 72 but I remember it was like working on some '40s radio.
John Strenk is online now
post #5 of 7 Old 12-21-2005, 11:05 AM Thread Starter
72JEEPCJ5
Yes, 72's are interesting....got ta love'em
Thanks everyone
post #6 of 7 Old 12-21-2005, 03:04 PM
kbtriumph
kbtriumph's Avatar
I just rewired my entire '74 CJ6, which is the same as a '72, and used the EZ-Wiring kit.
http://www.ezwiring.com/
I replaced all of my switches and lights at the same time. It took me the better part of a weekend to finish the entire project. I replaced everything because it is 30 years old and totally worn out. Everything works except the heater still doesn't put out any hot air (not an electrical problem).
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #7 of 7 Old 12-21-2005, 06:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I have rewired a number of Jeeps and have yet to use a kit. This is more because I'm a cheapskate than anything else. When you get the schematics, study them until you are comfortable with how the wires are run. One of the things I've done is adapt an existing loom from a donor rig. This allowed me to "clean up" an existing loom that has a fusebox already in it. The last one I used was off an early Bronco, however, most any of the simpler(IE early) looms will work. If you decide not to use an existing loom, then buy a couple old looms from a local U-pick yard. One of the looms should have a usable fusebox. Dismantle the looms and use the existing wires to replace the Jeep's loom. This will be much cheaper than buying a number of spools of wire and will provide you with color coding. While this method is somewhat labor intensive, it can usualy be done for well under one hundred dollars. More than that, the learning experience is priceless.
jeepdaddy2000 is online now
79 CJ5 Rewiring Zane98S14 Jeep CJ Forum 0 04-12-2009 04:43 PM
79 CJ5 needs rewiring! Mattg1 Jeep CJ Forum 2 04-01-2009 10:06 PM
71 CJ5 rewiring ?s armyhooker Jeep CJ Forum 1 01-13-2008 11:14 AM
I need help rewiring a 72 CJ5 72JEEPCJ5 Jeep CJ Forum 3 10-21-2006 05:43 PM
Rewiring '58 CJ5 ski dude Jeep CJ Forum 1 04-29-2002 09:56 AM
