Reverse lights wires, Location? - Page 2 - JeepForum.com
post #16 of 19 Old 09-15-2009, 10:21 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes it is, That would be the Orange Wire. When you ground that wire the 4WD light will light up. If you have a D300 there is a switch by the t-case shifter housing.
John Strenk is offline
post #17 of 19 Old 09-15-2009, 10:25 AM Thread Starter
DT5150
1983 CJ7
yes, i'm running a d300. so i could run the orange wire to the t-case.. good. does that require any special type of connector to attach it to the t-case? i haven't looked closely at it in quite a while.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #18 of 19 Old 09-15-2009, 12:36 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
its a round little push on connector, kind of recessed center pin that goes on top of the nipple of the 4wd indicator. but yes a specialty plug.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #19 of 19 Old 09-15-2009, 01:23 PM Thread Starter
DT5150
1983 CJ7
ok, i know what you're talking about. threaded with a pointed "nipple".. hmm.. that fitting is gonna be hard to find.
DT5150 is offline
no reverse lights meater Jeep CJ Forum 16 03-04-2008 12:48 PM
No Reverse Lights gtrpup2 Jeep CJ Forum 4 10-26-2006 02:44 AM
Brake lights and Reverse Lights CJeepster5 Jeep CJ Forum 9 05-28-2006 08:24 PM
reverse lights Sprue Jeep CJ Forum 3 01-08-2005 08:03 PM
Reverse Lights MudLover Jeep CJ Forum 8 12-02-2002 11:24 AM
