Reverse lights install and connection questions - JeepForum.com
post #1 of 3 Old 01-27-2010, 07:06 PM Thread Starter
bubba+78363
1981 CJ7
So I have about a 3/4" LED white light that I am going to be using as my reverse light. My question is how do I make it work by using a B&M T-shifter that has the switch already built into it. It has a roll of what appears to be speaker wire attached to. These are the same shifters being used for Line Loc's, and Nitrous Shots, and work with all 12v applications I know I am gonna have to use a relay for this to work, but not quite sure how to wire the relay up I completely re-wired my jeep bumper to bumper a couple of years ago and the new kit didn't have a wire for reverse lights. So I got to thinking bout the "what'ifs.
Thanks,
Matt
bubba+78363 is offline
post #2 of 3 Old 01-27-2010, 08:08 PM
GREASEMONKEY
T-handle brushed aluminum w/button
This what you are talking about?
If the button is a latching on/off
You only need to tap into constant power with a small fuse, 5A is sufficient to run the LED. Run the opposite wire to the positive LED wire, and then ground your LED.
If your button is a momentary on/constant off then you will need to make a latching relay bank.
Use the 4th or 5th diagram on this page Special Applications with SPDT Relays, Diagrams
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
post #3 of 3 Old 01-27-2010, 08:11 PM Thread Starter
bubba+78363
1981 CJ7
Thanks Bud that's exactly what I am looking for
Tach connection after msd 6200 install careyfl Jeep CJ Forum 18 01-27-2009 05:41 PM
quick help - cj a/c install, what hardware for idler pulley connection? CJ7 Vette Jeep CJ Forum 2 03-03-2008 06:45 PM
Please help, engine/tranny connection questions. egrasher Jeep CJ Forum 3 03-03-2007 05:47 PM
Brake lights and Reverse Lights CJeepster5 Jeep CJ Forum 9 05-28-2006 08:24 PM
Reverse switch connection Skrappi69 Jeep CJ Forum 3 02-28-2006 01:53 PM
