Reverse light problems - JeepForum.com
post #1 of 8 Old 03-04-2013, 04:40 PM Thread Starter
cjandanxj
So my reverse lights are not work and from what I have determined it is because the harness that comes off the tcase isn't plugged in but for the life of me I can't find where it plugs in. Sorry if this isn't clear
cjandanxj is offline
post #2 of 8 Old 03-04-2013, 05:21 PM
shadoow
The reverse connector is on the transmission not the transfer case. What kind of transmission do u have. On the T176/177's the connector is on top at the shift housing. On the T4/T5's the connector is on the side. (I think)
shadoow is offline
post #3 of 8 Old 03-04-2013, 09:47 PM Thread Starter
cjandanxj
I have the T176/177
post #4 of 8 Old 03-04-2013, 10:09 PM
turbonusse2
The t176 is on top. The t5 has a different connector than the t176
live and learn
turbonusse2 is offline
post #5 of 8 Old 03-05-2013, 06:41 AM
shadoow
Originally Posted by cjandanxj
I have the T176/177
Easiest way to get to it is to remove the tunnel cover inside the jeep. The connector sits just behind and to to left (toward driver side) of the shifter tower. It has 2 flat prongs sticking up a little
shadoow is offline
post #6 of 8 Old 03-05-2013, 07:00 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's what it looks like on a T-19.
Yours probably has different connector, but it should be roughly in the same location.
Matt
Matt1981CJ7 is offline
post #7 of 8 Old 03-05-2013, 09:09 PM Thread Starter
cjandanxj
Found it and the reverse lights are working but it appears the 4wd indicator light still won't illuminate any thoughts everything is plugged in and fuses are good
post #8 of 8 Old 03-05-2013, 10:07 PM
BagusJeep
1981 CJ7
Have you got it plugged in on the transfer case?
The switch on the transfer case grounds the end of the wire. It is fairly easy to test its function without removing it with a 12V test bulb and long leads. Connect on eend to teh battery positive and see if you can get the bulb to light up when connected to the switch or the harness going to it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
