Restore/Rebuild/Upgrade 81 CJ5 "Ol Nellybell" - JeepForum.com
post #1 of 2 Old 01-22-2010, 08:21 PM Thread Starter
frank c
1981 CJ5
Started to refurbish all exterior engine/bellhousing parts in anticipation of machine work on engine being completed. 3O over pistons and new everything including waterpump/distributor etc. Clutch kit.
I used Duplicolor Wheel paint on the Valve cover and then sanded off the fins and numbers to let the aluminum show for a two/tone effect,pulleys/brackets/etc. High temp silver paint on the exhaust man. and wire wheeled and clear coated the intake. Bellhousing is Rustoleum. P/S pump/brackets gloss black.
I am going to use the same bronze color on the Motorcraft 2100 body when I get it. The block and head I want to paint the AMC Metallic engine blue, should be a nice contrast when finished.
Clean an paint the engine compartment/rewire the whole darn vehicle,an I'm considering painting the exterior of the jeep body with Zolatone desert camo so I can sneek up on the gold nuggets and meteorites I will be hunting with Ol Nellybell when shes road/desert worthy again.
Any comments or suggestions out there are appreciated I've only just begun this task.
BEFORE
AFTER
frank c is offline
post #2 of 2 Old 01-22-2010, 10:54 PM
baja1ab
WOW! If this is a sign of how you're going to approach the rest of this rig I'd say she's going to be one sexy CJ. *****in job man!
baja1ab is offline
RipTech's "WipeBoy" wiper upgrade mmerlina Jeep CJ Forum 24 12-16-2013 03:16 PM
80 cj5 rebuild/restore tpallyn Jeep CJ Forum 3 01-26-2010 01:11 PM
burned out "REBUILD BLUES" jcooley7 Jeep CJ Forum 8 03-08-2009 04:59 PM
Bunch of "Should I" questions about my rebuild imtheant Jeep CJ Forum 3 11-16-2008 08:38 PM
Project - 1986 CJ7 - Rebuild/Restore JamieinNH Jeep CJ Forum 26 02-19-2008 08:41 AM
