resetting the combination valve brake warning light - JeepForum.com
post #1 of 4 Old 07-01-2011, 11:32 AM Thread Starter
Rusty Barrels
1979 CJ7
After I installed a new master brake cylinder on my 1979 jeep I bled the brakes without locking the valve and now the warning lamp is on all the time. What do I have to do to reset the valve and turn the warning lamp off? The brake system is non powered.
Rusty Barrels is offline
post #2 of 4 Old 07-02-2011, 09:16 AM
Dborns
When I replaced the rear pads, and bled the brakes, I ran into the same issue. I didn't do anything with the prop valve when I bled them even though it seems like its about 50/50 on this forum as far as the pin on the valve. My light was on also after bleeding, and it just took another round of bleeding to have it go out. There was still air in the line after the first bleeding. Try to rebleed them.
Dborns is offline
post #3 of 4 Old 07-02-2011, 11:17 AM
Mike Romain
That normally means you still have air in the lines. The switch is self resetting on the ones I have seen.
Mike
Mike Romain is offline
post #4 of 4 Old 07-02-2011, 12:32 PM
Turtle71
1983 CJ7
Try bleeding in this order. RF LF RR LR RF LF. I read somewhere that doing the fronts first is supposed to set the prop valve. Worked for me.
My 83 CJ7 Build:
Turtle71 is offline
Brake Combination Valve/Proportioning Valve Question Wrangler1642 Jeep CJ Forum 1 01-17-2011 04:43 PM
Brake Combination Valve - Help GuacaTex Jeep CJ Forum 5 12-22-2010 06:51 PM
brake warning light RH31379 Jeep CJ Forum 2 06-03-2010 09:28 AM
brake combination valve op-and-sons Jeep CJ Forum 3 04-09-2010 06:23 AM
brake warning switch on proportioning/combination valve whittlecj Jeep CJ Forum 1 10-24-2009 07:29 AM
