Republicans Shift Petroleum Exploration Focus From ANWR to My Garage Floor
| JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!! | Black Magic Brakes, KOH Weekend Special!! | Brand new! XJ Rear DIY Bumper from JcrOffroad! |
#1 | |
Do these things ever quit leaking lubricant out of random places?
So far I have done the following on my CJ to stop the leaks: 1. Replaced valve cover gasket twice, cleaned garage floor 2. Replaced rear-main and oil pan gasket, cleaned garage floor 3. Fixed front diff twice and rear diff once, cleaned garage floor 4. Fixed leaking Dana 300 pan gasket, cleaned garage floor 5. etc, etc, etc I'll be darned if I didn't come home today to find yet another oil spot on the floor. The dang thing now decided it would completely relieve itself of all the steering stabilizer fluid. It's like trying to house train a puppy. ![]() Anyway, a little Friday CJ owner humor I guess.
#2 |
It sounds like the govt. should come fix it for you.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge |
#3 |
Now thats funny . . . . . . .
Yep. . . .Finally got my rear end to stop leaking was embarrasing. Now moving to the front for a rear main and lastely to fix a PO project where he put a new manual oil pressure gage in and dorked up the connector tube to the motor. CJ life is good.
78 304-CJ5 |
#4 |
Mine don't leak, the last leak I fixed was the Power steering gearbox.
#5 |
If the stabilizer is leaking, it will need to be replaced.
The engines can be sealed up as well as any other. It can be a trick to get the t cases to quite weeping though,,, |
#6 |
quit yer bit chin and go clean the garage floor
#7 |
If you only knew what his user name meant...
#8 |
No Jeeps leak. They are simply marking their spot.....
#9 |
Jeep. There's Only One
It's a Irish Gaelic phrase meaning "kiss my *ss"
I'm still trying to get my TC to stop leaking around the front bearing cover. Had it apart 3 times already and just checked today and found a wet spot again on the skid plate. ![]() ![]() :
. 1984 CJ-7 Renegade __________________ Restoration Thread:http://www.jeepsunlimited.com/forums/showthread.php?t=434226 |
#10 |
Senior Member......NOT!!
It's almost like Jeeps should have a litter box..............
#11 | |
I've got to mop the coffee out of my keyboard....
"In the end...It's all Hack." |
#12 |
It's not a litter box they need but a diaper like you would see on young children or old dogs.
I recall my valve cover as being an issue, a clifford aluminum that the PO's PO put on but wrong year head & cover and just made it work with some grinding. This of course means no gaskets fit right. I'm embarassed to admit that I used an ENTIRE tube of black permatex in addition to a cork gasket. But it stopped.
-= Francis =- [SIZE="1"][I][SIZE="2"]These, in the day when heaven was falling, The hour when earth's foundations fled, Followed their mercenary calling, And took their wages, and are dead. Their shoulders held the sky suspended; They stood, and earth's foundations stay; What God abandoned, these defended, And saved the sum of things for pay. A.E. Housman[/SIZE][/I][/SIZE] |
#13 |
Hallowed be thy name....
I put a catch tray under mine when I park it and put whatever comes out I pour back in whatever it leaked out of...........
![]() That chit is too expensive to waste mayng!
79' CJ7 82' CJ8 94' YJ 96' ZJ |
#14 |
I always thought the leaky rear main was a factory installed option... I mean it leaks a quart, put a quart in. hell i never have to change oil again! Self Servicing Rear Main. I was thinking about getting an iv hanger off a hospital wheel chair and mounting it to the jeep with a bag of 10w30 haha
BLACK JEEP SOCIETY COAST GUARD WHEELERS "I'm driving, YOU get out and lock the hubs!" |
#15 |
buying stock in rightstuff and liquid copper permatex is a good way to start. also 4.0l with the blue expensive gasketseal beter then a 258 could anyday.
avoiding cork gaskets is key as well where i park at work it is a oil slick it looks like a drivethrough line in the gheto and a rainbow when it rains
83 cj7, white/pearl w/ black trim - 99'ax-15/clocked dana 300 twin sticked - 4"RC lift - HD shackles - 33X10.5 bfg mt's on micky' T 15" classic 2s - HD tierod flipped - custom bumpers with d-rings - winch - flowmaster - obd1 efi swap - 4.6L strocker with com smooth idle cam. soon to be: rear disc brakes,front and rear tube fender flares and better sliders, 3.0L mercedes turbo diesel power |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
