Replacing the valve cover on a 1981 CJ7. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Replacing the valve cover on a 1981 CJ7.
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-26-2015, 10:31 AM   #1
10charlie
1981 CJ7
I have a 1981 CJ7 the has a leaking valve cover. I ordered a new cover from Quadratec built made by Crown. The new cover came with the gasket and all of the hardware 5/16" bolts for the sides and 1/4-20 bolts for the ends. I started taking the old valve cover off and discovered the three bolts on the right side of the engine are unique in that that have a 1/4-20 threaded surface about 3/8" then there is a 5/16 shoulder on the bolt. As an added treat the rear bolt on the current cover is broken. So I will have to drill that one out and re-tap it.
On the left side of the engine there 3/8" studs going into the head these have a nut holding the head on and a secondary nut with a collar that catches the valve cover to secure it. The new valve cover does not have any shoulder for these retainers to catch and apply pressure. In addition, there are two holes in the cover with no corresponding holes in the head. My questions are as follows; do I need to drill and tap the head for the two 5/16" bolts on the left side of the engine? Where can I buy the unique bolts holding on the valve cover? Has any one else dealt with this issue?
10charlie is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 10:53 AM   #2
STJP
Street Jeep
STJP's Avatar
Search google with your thread title and you will get lots of jeepforum threads and others on the subject. Will answer all your questions.
STJP is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 12:12 PM   #3
Hawk4097
You should be able to extract the broken bolt instead of drilling it out and retapping it.
Hawk4097 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 03:22 PM   #4
keith460
Jeep. There's Only One
keith460's Avatar
I think your unique bolts are probably 5/16 shoulder bolts with 1/4-20 threads. Hardware stores will have them. Sent from my iPhone using JeepForum
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 09:10 PM   #5
10charlie
1981 CJ7
Thanks for the guidance, I didn't realize the holes were there and just needed to be tapped. I like the idea of using studs to keep everything lined up.
