replacing turn signal switch - JeepForum.com
post #1 of 5 Old 02-07-2014, 07:55 PM Thread Starter
seabass1858
1983 CJ7
Are there any surprises that I may run into while replacing my turn signal switch on my non-tilt column or is it pretty straight forward with the steering wheel puller and lock plate press tool? Also while im in there I will grease the upper steering column bearing.
seabass1858 is offline
post #2 of 5 Old 02-07-2014, 07:56 PM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
Standard GM model from the 1980s. Just keep tract of the springs and which way the horn contact assembly is oriented.
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
post #3 of 5 Old 02-08-2014, 03:42 AM
John Strenk
John Strenk's Avatar
1976 CJ5
There are subtle alignment marks you should note as you take it apart but otherwise it's pretty straight forward. Take pictures.
This also lines up the horn ring slot
The lock ring plate also has spines to align it up to the shaft. It can be forced on the wrong way and then your horn contact won't be installed properly
Here is the horn contact missing the contact button.
The hazard button unscrews and not pull apart as they often do.
You might want to tie a string around your old electrical connection before you pull it out to make it easier to pull the new plug back down.
Write "TOP" on the horn plate before you take it out so you know which way is up. If you mount it upside down, your horn will randomly sound.
John Strenk is online now
post #4 of 5 Old 02-08-2014, 07:14 AM
TaylorCJ5
1976 CJ5
Thanks John, I think I know why my horn randomly goes off now.
TaylorCJ5 is offline
post #5 of 5 Old 02-08-2014, 08:57 AM Thread Starter
seabass1858
1983 CJ7
Thank you
