Replacing Tub - JeepForum.com
post #1 of 3 Old 09-30-2002, 12:23 AM Thread Starter
Pat
Replacing Tub
Hi,
Im looking to purchase a 1972 CJ5. If I purchase it I will need to replace the tub. Is this do-able by someone who is reasonably mechanically inclined? Any information regarding this subject will be greatly appreciated. Pat
Pat is offline
post #2 of 3 Old 09-30-2002, 07:08 AM
RockJeep
Motobilt.com
RockJeep's Avatar
time will depend on tools you have, type of body your replacing it with, experience, etc. Fiberglass replacement will obviously be more time due to having to find new grounds for all your wires and more. if you've got a new or used metal tube then it'll be probably go quicker. also like most projects things will occur that you didn't plan on, like new body mounts/bushings might be needed, electrical wires, etc. you'll need to remove your fenders from the tub, your windsheild, roll bar, dash and guages wiring harness, steering column, all interior components, brake lights, etc. if your good i'd say a weekend to tear it apart and another to put it back together,(assuming your good and quick)
later
bob
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #3 of 3 Old 09-30-2002, 02:17 PM
DaveFL
DaveFL's Avatar
I looked at replacement tubs for my 81 Cj5, but after all the problmes I had with aftermarket Fenders and Hoods I decided Real quick to just repair the rust spots in my tub.
I would suggest trying to salvage your exhisting tub if at all possible. Dont know if I would go with a aftermarket metal tub, I have heard horror stories about them, but Im not a big fan of Fiberglass either.
As for how hard to do? Well I went into my project with minor mechanical knowledge, and Im moving along with a fram up Resto. Ive had my share and some more problems but so far Ive gotten more help from people on this board than anywhere else. It's not easy, and certianly not cheep but the reward will be well worth it.
Good luck
DaveFL is offline
Replacing the RMS on CJ7 w/258 CrazyHorse6 Jeep CJ Forum 7 03-15-2009 05:02 PM
304 replacing a 258 Fuzz21 Jeep CJ Forum 9 03-09-2007 11:58 PM
replacing 4.2 oil pan with 4.0 oil pan edge1 Jeep CJ Forum 2 12-03-2004 09:55 AM
replacing the tub puddle jumper Jeep CJ Forum 4 10-20-2004 07:06 AM
Replacing 258 with a 305 nvyblue_cj7 Jeep CJ Forum 1 05-15-2002 07:11 AM
