Replacing stock 21 Gallon - JeepForum.com
post #1 of 17 Old 06-10-2013, 02:24 PM Thread Starter
scottearl
To anyone who can help!
I have to replace the Gas tank on my 1984 CJ7. It came stock with the 21 Gallon Tank. Does anyone know if the aftermarket tank that 4WD/Morriss/Fourwheelparts sells will fit into the original skid plate?
Thank you
Scott Earl
scottearl is offline
post #2 of 17 Old 06-10-2013, 04:13 PM
texasdave
texasdave's Avatar
1980 CJ7
I got mine from MTS. They make fuel tanks for the military so I felt they should be good. http://www.mtscompany.com/
texasdave is offline
post #3 of 17 Old 06-10-2013, 06:12 PM
PERK
1983 CJ7
if you have a cj-7 20 gal. tank...no one makes an exact replacement.
PERK is offline
post #4 of 17 Old 06-11-2013, 09:32 AM
texasdave
texasdave's Avatar
1980 CJ7
Mts says theirs is an exact replacement.
post #5 of 17 Old 06-11-2013, 10:35 AM
scrapman
Actually, it says it is not.
STRAIGHT FROM MTS WEBSITE:
0051XL 1978-1986 Jeep® CJ 21 gallon tank. Does NOT come with skid plate. Includes skid plate extensions, new sending unit, lock ring and O-ring, and new top strap. Inline fuel filter required.This tank will NOT directly replace the original OEM 20 gallon factory "plastic" tank in any JeepCJ, a new skid plate and hoses are required. This tank will NOT physically fit in a CJ8 Scrambler. Dimensions 23" x 16" x 15"."
I checked it out because I have a factory 21 gallon and will probably need a replacement some day.
scrapman is offline
post #6 of 17 Old 06-11-2013, 11:17 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I just don't get why you can find replacements for everything BUT the 20gal tank. I had a 15gal replacement in mine, but it rusted out. The skid was perfect - still have it. If I could only find a replacement skid for the 20 gal I put in its place, I'd be happy. May have to go back to the 15 some day if I cannot find one.
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline
post #7 of 17 Old 06-11-2013, 12:16 PM
PERK
1983 CJ7
cutlass 327, are you looking for a stock 20 gal skid plate? if so PM me
PERK is offline
post #8 of 17 Old 06-11-2013, 12:59 PM
LumpyGrits
Since your in PRK, it's going to have to be C.A.R.B. legal too.
IF they are still round. I would look here for a replacement.
http://wrecking-services.cmac.ws/sco...g-repair/4224/
If the OP is looking for a club to join up with, ck out The Roughwheelers.
I was a member for over 33 yrs.
LG
LumpyGrits is offline
post #9 of 17 Old 06-11-2013, 02:49 PM Thread Starter
scottearl
Thanks everyone, this is what I found out. The stock 20 gal tank has no aftermarket. As suggested above by Scrapman the MTS is the way to go. However, the 20 Gal Skid Plate will not work with the MTS replacement. Looks like I have to get a Skid Plate from a 15 gal. set up and use the extentions from the MTS Kit. All this because of a Sending unit that will not seal. replaced the unit, the gasket, and the Nut.
Thanks again for your responses.
post #10 of 17 Old 06-11-2013, 02:54 PM
LumpyGrits
IF you had told us about the sending unit issue to begin with.......
Had same send'n unit issues.
Had to resolder the top of the SU where the tubes came through. NO ISSUE since then.
LG
post #11 of 17 Old 06-11-2013, 02:56 PM Thread Starter
scottearl
After I get this set up taken care of I'll have a 20 gal Skid Plate in decent condition for the taking.
post #12 of 17 Old 06-11-2013, 02:58 PM Thread Starter
scottearl
LG, my leak is coming from in and around the gasket. I can only figure that the tank is warped or something. All new parts and still leaking.
post #13 of 17 Old 06-11-2013, 03:09 PM
LumpyGrits
That's what I thought also with mine.
Make sure the 'nut' that screws down against the SU turns freely.
DBL ck to be sure you have the CORRECT "O" ring. This ares has to be SUPER clean.
Don't be afraid to coat the "O" ring with some silicon grease.
I still bet it's the soldered area on the top of the SU that's leaking.
Can you post GOOD pictures of the top of your SU and pictures of the tanks SU location?
"O" ring PN# is Omix 941521, which replaces Omix #17730.01
LG
post #14 of 17 Old 06-11-2013, 03:49 PM
Newbjeep
1972 CJ5
They also make a rvt type of gasket maker specially made for use with gasoline I coated my oring in it before installations and hasn't leave a drop
Newbjeep is offline
post #15 of 17 Old 06-11-2013, 03:58 PM
LumpyGrits
Source?
LG
